ZONA.OVRLND
- David
- May 10, 2018
- Phoenix, AZ
- Website
- www.instagram.com
- '21 392 Hemi Wrangler - Follow on IG @ zona.ovrlnd
- Build Thread
- Link
- Vehicle Showcase
- 1
So I've looked on the forum and haven't found anything related to this, unless I'm using the wrong verbiage so i'll just put it here as a new thread.
Does anyone know if there's a security bolt that can replace the factory bolts that go onto the Mopar steel front bumper? So i'm specifically talking about the factory bolts that hold in the end caps and that also would be used for a Mopar winch/grille guard, and even some other grille guards from Maximus-3 or Warn.
I will be installing the steel bumper, a warn winch, the Mopar grille/winch guard, as well as a couple KC lights on the bar, and was just curious if there's any security bolts that can replace the factory ones that is slightly more secure than just the torx bit that would be needed to remove what is there.
Thanks in advance!
Thanks in advance!
