TaiMc
- Tai
- Jun 23, 2018
- Houston, TX
- Website
- www.instagram.com
- '18 JLU Sport Mojito!, 3.6L & '18 Ninja 400 KRT
- Occupation
- Communications Manager
- Vehicle Showcase
- 2
So....I was extremely excited about buying my Jeep that I kinda forgot what city I live in...and forgot to be concerned about not having a security system! I realized that Jeeps with non-power locks have this particular security feature:
"The Sentry Key Immobilizer system prevents unauthorized vehicle operation by disabling the engine. The system does not need to be armed or activated. Operation is automatic, regardless of whether the vehicle is locked or unlocked. The system uses a key fob, keyless push button ignition and a RF receiver to prevent unauthorized vehicle operation. Therefore, only key fobs that are programmed to the vehicle can be used to start and operate the vehicle. The system cannot reprogram a key fob obtained from another vehicle. After turning the ignition switch to the ON/RUN position, the vehicle security light will turn on for three seconds for a bulb check. If the light remains on after the bulb check, it indicates that there is a problem with the electronics. In addition, if the light begins to flash after the bulb check, it indicates that someone attempted to start the engine with an invalid key fob. In the event that a valid key fob is used to start the engine but there is an issue with the vehicle electronics, the engine will start and shut off after two seconds. CAUTION! The Sentry Key Immobilizer system is not compatible with some aftermarket remote starting systems. Use of these systems may result in vehicle starting problems and loss of security protection"
But my concern is that my Jeep is Mojito! and it's gonna be gorgeoussss and it seems like it doesn't take much for someone to get in there especially without an alarm blaring. I was talking to an aftermarket rep at the dealer where I purchased my Jeep and I was quoted $499 (labor included) for AudioVox Alarm (Factory Keyless Entry)...but at first she said it was for power locks...then she said it wasn't.
So, I'm trying to get another opinion on an alarm that doesn't require me getting power locks and that will be compatible with this Jeep's "Sentry Key Immobilizer System"; was hoping someone already has one installed without it conflicting with the security feature of the Sentry Key.
Any help is appreciated!
