Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
Well you've almost come full circle, the aux battery is there for the voltage drop from starts...but not the ess ones?Yes, Aux is AGM Lead Acid.
Flooded carb? That has nothing to do with a JL. A completely different and irrelevant scenario where you keep engaging the starter without starting the engine to recharge the battery. That is night & day different from normal ESS use.
ESS a smart system. If you do hit a lot of lights in rapid succession ESS will stop engaging if the battery needs to recharge. If the batteries are failing it won't engage. It's also a smart recharging system which will pump up or reduce the charging voltage as necessary, which also didn't exist in the carb days. ESS will never run the battery dead in a JL. It will stop engaging well before that happens.
What can't be controlled is how long the JL sits parked with electronics parasitic draw, which drains and sulfates the batteries. When that happens, over time a significant voltage drop can occur when the starter engages for a cold start. That is what Aux is there to avoid. On the JL, insufficiently powered electronics means complete engine failure. The engine is no longer physically controlled by driver actions anymore.
