Seat disassembly for leather seat install
blue89bird
NJ
21 Rubicon Xtreme Recon
There seems to be literally no info on this so I decided to take a whack at it.
I’m nowhere near done so bear with me and I’ll post more info and pictures as I finish.
step 1: unbolted seat. You can use the wrench that came with the jeep it’s the larger bit I think t50
step 2:on the bottom of seat, unclip the 2 stretch connections from the hooks.
Jeep Wrangler JL Seat disassembly for leather seat install F57122F8-A1B6-47A9-8D9A-56F7F5659154
step 3: unscrew 2 screws from bottom of backrest.
Jeep Wrangler JL Seat disassembly for leather seat install 709303BD-4574-46EA-8611-CEE4C8270B50
step 3: remove seat back - pull on bottom to unclip and then slide down, wiggle you’ll figure it out it’s pretty tight
Jeep Wrangler JL Seat disassembly for leather seat install 997208D1-FFE7-4D72-A588-F0D8065570A1
step 4: the hinge covers on the side need to be removed. Driver side is easy 2 screws. Passenger side is a pain. You need to remove the same 2 screws then pry up on the side cover and remove that
Jeep Wrangler JL Seat disassembly for leather seat install 770E4844-97DE-41C5-8B6D-EB78DA49FB82
Jeep Wrangler JL Seat disassembly for leather seat install 0E78C708-E870-47B7-B3B3-2F0D3D363AC6
Jeep Wrangler JL Seat disassembly for leather seat install 37FD15E6-51C8-416A-AE8D-607488BD933F
Jeep Wrangler JL Seat disassembly for leather seat install A453C7A5-BEEA-42BC-BA73-1F28A0AAA55B
Once that’s done you can start to remove the cover. There’s a bunch of plastic clips around the entire perimeter where the seat back was, the bottom, etc. just keep removing them until it’s held on by the hog rings. You can then cut them off. Once they’re all removed you can remove the airbag. It’s held in with 2 10mm nuts on the inside of the seat frame. The harness for it is held in with a bunch of Christmas tree clips that you’ll need to remove.
then you get here:
Jeep Wrangler JL Seat disassembly for leather seat install 10F14016-10D7-4486-9B83-0A0C7E5E31B6
To be continued
Ct_Formula
Orange Ct
2021 Rubicon JL, 2011 JK Sahara
Self Employed
Wow!
Atticaz
Christopher
AZ
2018 Jeep Sahara
I just did my wife’s front seats. It’s way more exhausting to do these seats than my Mustang was. Phew!!
Now to tackle the back seats. Any idea how to remove the rear headrests and the seat levers? Any help would be appreciated.
Jeep Wrangler JL Seat disassembly for leather seat install 8AF41438-9B4D-4B90-AA90-A5816005D2DC
Jeep Wrangler JL Seat disassembly for leather seat install A538634D-DDA3-4430-A37E-E013FD05F2E4
Jeep Wrangler JL Seat disassembly for leather seat install A46810D3-8E04-4252-9547-167738212B06
Atticaz
Christopher
AZ
2018 Jeep Sahara
Nevermind. I figured out that the leather just needs to worked out from under it. Just like the headrest levers.👌🏼
Packnbeer
Jamie
Davenport, Iowa
2021 Jeep Wrangler Sport S 2-Door
how did you get the leather around mechanisms like the lumbar knob, etc
Atticaz
Christopher
AZ
2018 Jeep Sahara
The lumbar knob can be removed by popping off the cap of the with a flat blade screwdriver. Then there is a Philips head screw to remove.
The seam for the knob cap is virtually invisible as it’s covered slightly by the rubber.
Packnbeer
Jamie
Davenport, Iowa
Thank you. Those look sharp as hell on there!
Atticaz
Christopher
AZ
2018 Jeep Sahara
Thanks. I was working on the back seats today. Got the 1/3 section almost done. There’s definitely some tips and tricks required for the back.
I’m may make a list of tips and tricks and post them up soon.
Jeep Wrangler JL Seat disassembly for leather seat install 6AB42C06-F142-41C0-A786-813D4AA4F82A
Atticaz
Christopher
AZ
2018 Jeep Sahara
Done! Phew. The back seats are a bitch. I did them completely without removal.
Jeep Wrangler JL Seat disassembly for leather seat install 66DE6D8C-D5F2-4CFD-97BA-151A8C8B29A2
Atticaz
Christopher
AZ
2018 Jeep Sahara
Tips for doing the back seat.
-On the 1/3 split section, behind the driver, the inner hinge bolt needs to be removed.
Jeep Wrangler JL Seat disassembly for leather seat install 4413D37E-ECF5-4911-AF8E-2F2FCA8E920A
-After unzipping both sides of the seat backs, you will need to flip up the cushion to access the two bolts for the headrest. This will make it easier to get the headrest cushion
Jeep Wrangler JL Seat disassembly for leather seat install 944030F9-245B-4365-990B-6F0DCEE47336
To remove the headrest cushions, you need to pry the retainer clips outwards.
Jeep Wrangler JL Seat disassembly for leather seat install 708BEE8F-722E-4DC8-A1B5-AD161E37FCC1
-I used a flat blade screwdriver to untuck the original covers from under the seatback levers.
Jeep Wrangler JL Seat disassembly for leather seat install 855D0681-C734-445A-A365-6C3B3E89F27D
-The anchor point bezels just pop out, with a pry tool.
All the rest is pretty self explanatory. New holes will need to be cut if you buy new covers. That part was kind of nerve racking. But I got through it.
