Seat Belts buzzing when windows are down.
iznthesky
Edgar
Humble, TX, USA, EARTH, Milky Way Galaxy
2018 Jeep JL Rubicon & 2004 Jeep TJ. Previously owned 1993 Cherokee, 1980 CJ5, & M151A2 while in the Military. For the love of Jeeps !
Beautiful Weather today and I was driving with the windows down....it was beautiful until I sped up and the wind began causing both seat belts to quickly begin oscillating back and forth...they were striking the Pillars while oscillating; causing a loud buzzing noise. It was a disappointing.
Does anyone have a trick or suggestion to quiet these whipping seatbelt...or to secure them so they don't drive me crazy.
Of course I have already been told to "Roll up your windows".....and "Slow down." Apart from those suggestions which are not options, I am open to new suggestions. Please advise. Summer is coming and I want to enjoy the JL topless.
TheWingman
2018 Firecracker Red JLUR
Pull each one all the way out to remove the slack until they start ratcheting, and then buckle them into their respective buckles. Pull tight to remove all the slack until they are taut. The ratchet mechanism will keep the tension on the belts to keep them from flapping. I do this when topless and/or doorless for freeway travel, works very well.
RCH
RICHARD
NORTHERN VIRGINIA
2018 JL RUBI 2dr 2.0t, 2014 CHEROKEE TRAILHAWK
Small bungee (or Velcro wrap) around the belt to the pillar. Even a rubber band will do it. I also have just tilted the pax seat back and then captured the singing belt between the seat back and the pillar. I only have the two door so don't know if the back seat belts sing in a JLU. The front belts sure do.
v/r rch
Keeper
Seacoast NH
'19 Sport Granite
Until I find a better solution, raising the window 1 inch stops most of the buzzing.
Rhinebeck01
2018 2dr. Rubi
@iznthesky
For a remedy, read here:
https://www.jlwranglerforums.com/forum/threads/padding-black-for-interior-protection-padding.24550/
Bearded_Dragon
FL
2018 Mojito! Rubicon
SilverSahara
Western Washington
2018 JLU Sahara
I hate seatbelts, so I use this. Problem solved. Just don’t crash...
IowaRaider
Iowa
2018 JL Sahara
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
I think you’ve completely missed the point of this thread. He’s talking about the wind buffering causing the seatbelts, the rear ones, to flap against the seats and possible the body plastic trim panels. It’s incredibly annoying. I have found the best fix to be turning music up louder.
iznthesky
iznthesky
Edgar
Thanks to everyone for your advice.
Bearded Dragon's recommendation of the pads around the seatbelt along with RCH's Bungee is what I am going for in a solution.
Thank you. Great solutions to this issue.
After I get it done, Ill post a pic or two.
Rhinebeck01
2018 2dr. Rubi
@iznthesky
I tried the strap thing around the belts and also tried a black sheep skin thingee ... but with either the belts did not want to retract properly... was a pain in the arse... That is when I oped to go with the felt pads. You do not see those and they do not hinder seat belt retraction.
iznthesky
iznthesky
Edgar
Rhinebeck01 Thanks. I am going to try those also. I don't want to the flapping sound of the seatbelt to interfere with enjoying the open air that jeep offers when the top of off.
Icon Vehicle Dynamics
