pantheman75
- Ryan
- Feb 9, 2018
- Washington
- 2022 Cherokee Limited, 2023 Wrangler Rubicon 4xe
I can get the grill off no problem. I can get the grill inserts off no problem. I'm asking about the camera wiring that's attached to the main grill... do I just pull the wire mounts outward to detatch them?No brutal force needed. There is a connector to disconnect to remove the grill from the vehicle then when you get the grill on a flat surface to start switching components it will be obvious.
