CMTAZ
Thanks that is pretty much what I've found. My Willy's has a hardtop but none of the other stuff. That's why I'm thinking that a 91 / 92 would be a better fit. The 97 would probably work, but might cause a lean to the driver's side. If I change out the springs, it's just to get that 1 - 2 inches. I just replaced the 255/75 17 mud terrains with 285/75 17 all terrains. This should set the Willy's up like a Rubicon on 34 tires.I gave you the info. I’ve run some VIN’s in the past. It would be as both you and I said on the front. The 97 would be on the passenger side because I ran a VIN like that. It had steel bumper, hardtop, towing, and that optional cargo rail system in the back.
Thank you
