JLR_AEV
- Dec 8, 2021
- California
- 2020 Jeep Rubicon AEV Outfitted
Hey guys and gals, hoping I can use your brilliant/experienced minds to answer my question(s)
I have been doing a ton of reading and could not find any information on this nor anyone has actually tried this
Context: I have a Rubicon with AEV tire carrier and Maximus roof rack that have made the rear droop. The difference is 1.75 inches of droop in the rear versus the front(measured from the ground and center of the wheel to right where the fender starts). I am not a rock crawler and solely do trails and overland so I will not be getting a lift.
Can I just add a rear teraflex 1.5 rear spacer and add longer bump stops WITHOUT adding any type of spacer in the front?
I have read about people running small spacer lift in either front or rear to level height out but I wasn't able to find anything on 1.5-2 inch of spacer to be in the rear only.
Will I run into any issues only running 1.5 inch spacer on just the rear to level it out?
The kit I am looking to buy but obviously only use the rears. I also wish Teraflex had a .25 inch spacer that I can stack to even it out completely at 1.75 but 1.5 inch spacer lift will have to do unless anyone has ever done something to add more height.
Thanks in advanced!
Thanks in advanced!
