S&B Filters Hood Scoops for your Rubicon Hood - DIY Install video
JEEPIDON
Charlie
Forsyth, Missouri
2021 Rubicon, 2021 Gladiator Rubicon, 2013 Ram2500
Retired - Business Consultant
Noticed any real noise difference w/o the silencer pad?
Honestly, no. The only thing I see this used for is for draining underneath the fake vents on the Rubicon. Once you cut that out for the S&B scoops, they have no purpose! The pad is as brittle as a potato chip and discolors. Looks much cleaner with it gone to recycling!
Dave, I’ll go take a photo and show you the hoses I added and how much better it looks without the pad.
JEEPIDON
Charlie
Forsyth, Missouri
Dave, here are some photos
JEEPIDON
Charlie
Forsyth, Missouri
Nice work. You have part numbers or Amazon links or anything like that for what you used?
Thanks!
The hoses did not come with the scoops...however, it's just simple Home Depot stuff:
The little round "dudes" are 1/8" plexiglass (I had them from another project but you can use whatever shape or thickness you like.
The elbows are cheap plastic 1/4" PVC hose elbows from the plumbing department.
The hose is just a length of clear plastic hose (fits the elbow of your choice) from the plumbing department.
Screws are 3/4" wood screws (pilot hoses drilled first).
The hoses simply are inserted into the hollow hood seals on your hood already. The nice thing is they drain out in the back of the fender right on the ground!!!
Just drill out the plexi and glue in the elbow. Silicone around the plexi/elbow when you screw it to the scoop underside.
Nothing to it, less than $10.00 in parts and just a fun little project to do.
The two circular lights that you may have noticed are from KC called cyclones and they are very bright and really light up under the hood at night. They're just wired on a toggle switch under the hood so you can turn them on/off if you have the hood open.
Have fun in your garage!
Charlie
JEEPIDON
Charlie
Forsyth, Missouri
Those drains where you attached the hose to did they come with the scoops?
Hows things in Aliquippa? I used to live in Ingomar not to far away from you!
MichaelAnthony
Michael
Aliquippa, PA
2019 Wrangler Rubicon JLUR, 97 Centurion Dually 7.3, 97 Classy Chassis Dually 7.3, 2016 Ultra Classic CVO
LoL it's ok I guess, I spend more time working out of town. Like now......
Miggy217
Miguel
South Florida
2018 JLU MOAB
It’s been a while since these posts, curious about how you all are liking your scoops, almost a year later?
I just ordered the scoops + an S&B cold air intake (arriving Saturday) but not 100% sure about the scoops yet. I think they look kinda cool but water is a concern (living in Florida).
Tech Tim
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Part of the Northridge4x4 team
We're still running them on that red JL here in rainy WA. Only putting the block off plates in place if it is an absolute downpour.
Have not seen any water in the airbox.
They do have a pretty cool water drainage system on the scoop that feeds the airbox.
Bumps Ahead
Valerie & Dion
Chatsworth, CA
ontherocks4x4.org
2021 JLUR 4XE
Happy Wife, Happy Life....
Been on backorder since April 18th with Quadretec.....are they in stock at Northridge 4x4? Maybe I need to cancel and order elsewhere.....
Jeep Wrangler JL S&B Filters Hood Scoops for your Rubicon Hood - DIY Install video Order_Details___Quadratec
Northridge4x4
Silverdale, WA
www.northridge4x4.com
2016 Sahara JKU, 2013 Rubicon JKU
Seller of badassery
26 confirmed
Gene
2020 Wrangler Rubicon eco diesel
It says for the 2.0 and 3.6, will these work on the diesels?
40”JLURD
Ross
Southern California
2021 JL Unlimited Rubicon Diesel
Bad Mother Fucker
While I'm still a little on the fence about the looks, I went ahead and installed the scoops (scoops only) to see if they provided any noticeable cooling effect. I ordered a new silencer pad for around $30, so I can always go back to stock if I want to.
I've had them on for about two days in 95 degree GA weather with 10,000% humidity. I haven't really noticed a difference in the temp readout on the display, but one thing I have definitely noticed is that my loudass fan almost never comes on anymore. I don't think I've heard it since I put the scoops on. And I'm a frequent windows down, no AC guy, so I always hear that damn Boeing-sourced fan spooling up for takeoff.
I'll go a few more days and see if the fan use is indeed reduced, and will see how they do in rain.
Well they look sweet at least...
40”JLURD
Ross
Southern California
Bad Mother Fucker
I’m sure the hood is the same and the intake is definitely NOT.
So yes the hood scoops will work. Although the intake will not (at least until they make a Diesel specific one that plays with these scoops)
