AncientCityJL
- Coop
- Feb 10, 2023
- St Augustine, FL
- 2020 JLR and 2022 JTR
- Build Thread
- Link
- Occupation
- amateur tattoo artist and semi-professional race car driver
Yesterday, I installed these. The installation was easy enough I didn't need to refer to the instructions - I actually left the instructions in the box. As with most stuff from Rusty and his guys, the products aren't rocket science. They are straightforward, easy to understand, and go on without any problems. I do have the drop brackets from Metalcloak in the rear so that is a major sticking point I still have to contend with today. I have to drill holes to further secure the step/sliders to the frame at certain points and the DB3 Rear Control Arm Correction Bracket system is 100% in the way. It isn't a big deal - I only need to remove my rear control arms at the frame and let them droop so I can drill a hole and install one grade 8 bolt to further secure the slider/step mount to the frame. Or try to snake a 12" long 3/8" drill bit through all that scaffolding without breaking it. Man, I wish I was 18 years old again.
The body mount bolts were no problem. Actually, they were a joke; they came off without a hitch. I did order rocker guard skins but they haven't come in yet.
One important note: I did 271 the body mount bolts when I re-installed them. That may be an issue when I go to install the rocker skins. You know, because I might have to remove these steps... The vast amount of red in my neck makes me use 271 like its mustard on a hotdog. I may be in trouble here.
