Rust on rear wheel hubs?
slim_pickens
Indiana
2022 Wrangler Unlimited Rubicon Xtreme Recon
I've got about 7k miles on my 2022 Wrangler Rubicon Xtreme Recon. Today I did a 5-tire rotation.
After pulling off each of my rear tires, I noticed that the wheel hub had a decent amount of surface rust. By contrast, the front hubs were fairly clean.
So two questions: Is this normal? And any advice on how best to clean these hubs and prevent future rust buildup?
My understanding is that taking a wire brush to these is OK but you should not lubricate these in any way because you want the wheel to remain tight against the hub. Still, I'm a little bummed these rear hubs look like they do after only 7k miles.
Thanks!
  • Haha
Reactions: LCW
Wkaz
MA
2021 Sahara
I brush them down and hit em with cold galvy paintas needed.
roaniecowpony
Retired Engineer
Normal. Front and rear hubs always get rusty. Paint them or spray with an anti-corrosion like WD-40 Specialist Long term-corrosion inhibiter.
slim_pickens
Indiana
I actually misspoke earlier. The rust I'm seeing on the rear is I think on the hat / cap of the rotor and not the wheel hub itself.
I know rotors get replaced eventually anyway, but would it still be worthwhile to brush these up and spray them with a corrosion inhibitor?
roaniecowpony
Retired Engineer
If you are in a wet climate or where they salt the roads, you need some protection on the hub flange and rotor, or they will rust solid and be a nuisance to remove when you need to do the rotors.
