the_jeepeo
Anyone know of a DIY article that covers running charge circuit wiring to the rear for a trailer battery?
First use a wire loom to protect the wires from the elements, You cam run most of it through the frame abs simply wire tie the loom to the frame where you cannot run inside. It is a very simple and obvious path when you get down there and look.Anyone know of a DIY article that covers running charge circuit wiring to the rear for a trailer battery?
