running 37's with just a lift?
  1. AmesosaurusRex
    AmesosaurusRex Well-Known Member
    First Name:
    Justin
    Vehicle(s):
    JLUR Punk'n Metallic
    Jul 12, 2018
    Spartanburg, SC
    54
    Liked:
    This is what I am looking to do. Are you noticing any rubbing at all under flex?
  2. Peanut Butter
    Peanut Butter Well-Known Member
    First Name:
    Pat
    Vehicle(s):
    JL?
    Mar 4, 2018
    Boise, ID
    170
    Liked:
    246
    I haven't taking it on anything difficult, yet.
    The MXT run pretty true to size and I expect
    them to rub the plastic in the back. I haven't molded the wheel well yet.
    If I get it out this weekend, I'll let you know.
  3. JMONEZ
    JMONEZ Well-Known Member
    First Name:
    Jared
    Vehicle(s):
    2019 JLUR
    Nov 29, 2017
    el dorado hills CA
    323
    Liked:
    184
    Occupation:
    Self employed
    Garage Profiles:
    Any rubbing issues with MC lift and 4.75 backspace?
  4. Jerrybizzle
    Jerrybizzle Well-Known Member
    First Name:
    Jerry
    Vehicle(s):
    2019 JLUR
    Aug 28, 2018
    Idaho
    160
    Liked:
    97
    Occupation:
    Tech
    I have a similar setup. Rough country spacer lift with 17x9 +12 (5.5 bs) and 37x12.5 mastercraft mxt. I do rub a little here and there when off roading but nothing I’m real concerned about. Real minor. Here’s a few shots flexed out. I did install the rear bump stops in the 3 inch position vs the 2 inch and I’m glad I did, the 37s are real close to the rear fenders but still get plenty of flex.
  5. ChattVol
    ChattVol Well-Known Member
    Vehicle(s):
    JLU 6 Speed, 2016 Odyssey, 2014 Accord
    Jun 29, 2018
    Chattanooga, TN
    1,434
    Liked:
    978
    Are your rear tires rubbing only on the inside or also on the top? In your pics, it looks like the rear has another 2-3" of uptravel before it hits the top portion of the fenders. With 37s, most seem to be running less than 5.5 backspacing to push the tires away from the inner fender/control arms and widen the stance to allow more flex. I'm running 5.2 backspacing with 35s, rubi fenders, 2.5" lift, with 2 bumpstops in front and 1 in rear and it flexes well with tires clearing the fenders by about a 1/4".(see pics below) Naturally, I'd like 37s bc they increase belly height and look proportionate. However, I dont want to have to buy another set of wheels with less backspacing to clear the fenders and flex well. The RK control arms are straight and don't help tire clearance...most lifts recommend backspacing of 4.5 or less, but I'd like to eventually put 37's on these wheels if 5.2 backspacing will clear the inner fenders....can adjust the steering stops to limit the turn radius a bit to clear the LCA's.
    Jerrybizzle likes this.
  6. Martindfletcher
    Martindfletcher Well-Known Member
    First Name:
    Martin
    Vehicle(s):
    Ducati 1299s, 2018 JLUR
    Jan 3, 2018
    San Diego
    1,397
    Liked:
    1,214
    1 3/4 Spacers work pretty good with RK arms and stock wheels, I had minimal rubbing lock to lock with 37 sst pros
  7. ChattVol
    Vehicle(s):
    Jun 29, 2018
    Chattanooga, TN
    1,434
    Liked:
    978
    Yeah...I'm not a big fan of wheel spacers. What company did you get to mount 37" STT Pro's on a stock 7.5" wide wheel?
  8. Martindfletcher
    First Name:
    Martin
    Vehicle(s):
    Jan 3, 2018
    San Diego
    1,397
    Liked:
    1,214
    discount tire did it and mounted the spacers successfully.
  9. Jerrybizzle
    First Name:
    Jerry
    Vehicle(s):
    2019 JLUR
    Aug 28, 2018
    Idaho
    160
    Liked:
    97
    Occupation:
    Tech
    Yeah I have higher backspacing than most. It was still rubbing the lower portion of the rear fender in Moab but not real bad. Just a little. It may have a little more room to stuff but I don’t think it’s more than an inch. Would rather save my fender vs get an extra inch of flex. If I end up doing fender mods I may switch the bump stop setup, but it’s good with me for now. I knew going in that many run less bs wheels, but am hoping these work and have so far. Plan on getting the mopar lift eventually and people run those with stock wheels so I should be fine. These wheels do push the tire out 2 inches from stock wheels.
    Also should add the axle is still a little shifted from the lift, but am adding a track bar relocation bracket in the rear which will hopefully recenter it and then may be able to tuck inside the fender. TBD
  10. ChattVol
    Vehicle(s):
    Jun 29, 2018
    Chattanooga, TN
    1,434
    Liked:
    978
    Once you get the rear axle centered, you could get a cheap heat gun and easily remold that rear inner pladtic fender piece to create space or remove that piece all together. One of the advantages of higher backspaced wheels like ours is tires will tuck inside the upper lip of the fender allowing more uptravel.(if the tire clears the inner fender) In your pic, it looks like the rear tires have atleast 2-3" of upper fender clearance left to further tuck the rear tires. Look at my rear tires tucking into the wheel well in the flexing pics...they aren't rubbing anything.
Loading...
Share This Page
