Rugged Ridge Spartacus HD Tire Carrier Installed
TJEli
Eli
MI
Jeep, truck, car
After being less than impressed with the current offerings for bumper/tire carrier options I decided to give a tub mount reinforcement a try. I already had the RC tire bracket installed and my gate was holding up just fine but this was for piece of mind. This hinge kit is BUILT. I am sure it is similar to some of the other ones out there but I was impressed. Cast aluminum bracing with steel hinges and hardened pins. 8 bolts to the gate and much thicker plates to the tub. I cannot make my tailgate flex at all by pulling on the tire now. At around $400 it is not inexpensive but it is less than some of the others out there. On to the pics....
-Eli
RenoMD
DC
Reno, NV
2019 JL unlimited Rubicon
Nice... I’m digging the method 701 bronze... I’m still wavering whether it would be too bling on my sting gray JLUR.
LLRubylady
Lisa
Long Island
‘18 Rubicon Mojito!
Thanks for posting. I was looking at this. Think it looks better than the Mopar.
Seanst34
Sean
Waxhaw, NC
3018 Jeep JLUR 2.0 L 4 Cylinder Turbo on 37s with 2” Mopar Lift, Inginity QX60, and BMW R Nine T Scrambler
Installed mine today after waiting two weeks for my local 4 Wheel Parts store to source it from CA after ordering the wrong model for the JK. It’s relatively easy to install and seems to be stout. I had a similar SmittyBuilt Pivot HD tire carrier on my JKUR. Seems to be about the same. One thing to note is that even though I called rugged ridge prior to ordering to confirm it would work well with the Mopar tire relocation bracket for 37” tires it did not. The Mopar bracket does not sit flush against the right side of the Spartacus hinge assembly so the tire is kicked a bit. Nothing noticeable but annoying. The tailgate is a little harder to open but way better than a two step swing arm assembly. I’d recommend it as a solid cost effective option if your carrying anything over a 35” tire.
TJEli
TJEli
Eli
MI
Jeep, truck, car
  • Thread starter
  • Thread Starter
  • #5
I have the RC tire relocation bracket and it sits flush with that one.
VGxHC
Pittsburgh
19 JLU
-Eli
I'd like to pick your brain about this a little bit, as I just installed mine, and I am also running a RC riser plate.
The gap on the right side of the tailgate/body is extremely tight and it feels as if the tailgate is lower on the left side when going to shut the gate.
Any ideas?
TJEli
TJEli
Eli
MI
Jeep, truck, car
  • Thread starter
  • Thread Starter
  • #7
Any ideas?
Take your spare off and close the gate. Check all your gaps. Loosen the bolts that fasten the carrier to the tailgate. (not the bolts inside the tub) You should be able to move the gate around a little bit with the bolts loose. Try to fix your gaps and tighten the gate down with it HIGH on the drivers side. The weight of your spare tire will pull it down in line.
If you are unable to get things lined up by loosening the bolts you will have to do it with shims under the hinge plates that bolt to the tub.
-Eli
aerosynch
Luis
Miami, FL
2018 JLUR Bright White
Are you running this with 38s now? How is it doing so far? I am looking for a carrier to support a 39" BFG and Raceline beadlock and just ran into the Rugged Ridge. I looked at the Teraflex but they don't have a hinge yet; only the tailgate part.
TJEli
TJEli
Eli
MI
Jeep, truck, car
  • Thread starter
  • Thread Starter
  • #9
I am. It holds up perfectly fine. I would not hesitate to put a 40 on it. I can hang on my spare tire and the gate doesn't flex.
-Eli
BrnxBomr2
Bucks County
Would this have a problem holding a wheel & tire combo that is close to 110lbs? I am thinking of running this with the Teraflex Alpha tire carrier.
aerosynch
Luis
Miami, FL
I had the same thought. Ordered the Alpha already but waiting to see what Teraflex releases to go with it, or try with the Rugged Ridge.
TJEli
TJEli
Eli
MI
Jeep, truck, car
  • Thread starter
  • Thread Starter
  • #12
My wheel and tire combo is 108lbs. It could hold more.
Rigby
Up North, Michigan
18 Rubi OB
Installing mine today and had a question. Did anyone plug the hole after removing the right side tire bump stop or do you just leave the hole open? @TJEli @Seanst34
Quake LED
