Rugged Ridge Front Bumper
brotherGood
OH
2021 Jeep Wrangler Willys
Our new to us '21 Willys came with a pre-installed Rugged Ridge front bumper. There are a couple spots where it looks like the finish has come off and rust is starting to peek through.
Per the website, this was powder coated. Should I take it off and have it re coated, or just sand it and paint it? I've never dealt with powder coating, so Im curious how paint would adhere.
https://ruggedridge.com/p/rugged-ridge-hd-stubby-front-bumper/v/jeep/wrangler-jl/2021/
Thanks.
IceBerg
SW Missouri
2021 XR 392
Just knock off the rust with a scraper, small brush, or wire wheel and touch it up with some black spray paint or automotive black touch up paint.
IF it bothers you that much it's probably close to the same cost to just buy a new bumper compared to stripping and reapplying powder coat.
brotherGood
brotherGood
OH
Im cheap, so my initial reaction was just to take the bumper off and spray it..ha!
I just wasnt sure with the powder coat as the "base" if paint would still adhere to it.
dbp512
don quixote
South of Sanity
'06 Yellow LJ, '23 Grey JLU
I have the full width version of that bumper, and rust inhibitor spray paint works fine. It actually is a pretty close match for the color & texture
brotherGood
brotherGood
OH
Now that you mention the full width, thats what I have. I just grabbed the wrong link..ha!
Did you just spray the rust inhibitor, or did you lay that out as a base and spray something else over top?
dbp512
don quixote
South of Sanity
I used the discount rust-oleum that Harbor Freight used to sell (can't find it on their website, now they got the name brand stuff) and just gave it a few sprays before letting it dry. No prep work and nothing after to finish. Although my bumper was new, I just scraped it a bit fighting with it to get the winch installed, so it was to prevent rust instead of fixing it. So depending on how much rust your bumper has, it might be a bit more involved.
brotherGood
brotherGood
OH
I've got a small spot where its (the rust) actually showing through near the hook on the DS, and then a couple small spots that have bubbled.
I do plan on adding a winch though, so maybe Ill do that sooner that later (or even while it's off). Not that she would ever use it, but the space is there so it needs to have one.
Blade1668
Darrell
N Alabama
91MJ,90XJ,91XJ,05,LJ,05JT
Thanks.
I've got a similar one that was made for JK, the "best" fix is order delivery strip and paint yourself actually. I got the spots with rattle can.
dbp512
don quixote
South of Sanity
If it's what I'm picturing, then I'd likely just hit it with the rust inhibitor paint and call it a day. As for the install, if I remember correctly the skid plate prevents you from accessing the bolts for the winch once it's installed, so it makes sense to add it first.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
As others have said, chip off the flakes, hit it with a rattle can of paint. Re-powder coated, Probably the cost of a new bumper or close to it.
My method: I removed it. Used a grinder and took it down to bare metal. I used a can of herculiner bed liner. It's holding up better than the powder coating, over 2 years now.
Jeep Wrangler JL Rugged Ridge Front Bumper IMG_2023)
Flip
Johnny
Virginia
I’m with @Flip on this one. I sanded , primed and bed lined. Looks great
Many moons ago, I purchased a barricade rear bumper for my TJ. The powder coating started to flake off inside of 6 months. I was furious. I scraped off the flakes, touch up painted it for years. I didn't know about the bedliner back then. No more flaking, scraping, and painting, Its solid!
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I found out about through the forum. 9maybe your post😊) It was surprisingly easy to get a great finish. Your front bumper looks really great. I bought a beat up steel bumper off of marketplace, and for under 150 bucks refurbished it. I did replace the plastic pieces, and some bolts were missing
Flip
Johnny
Virginia
My current bumper was really inexpensive when I bought 2 years ago - $225. Now they're over $400. I did a bull bar delete. At first I started to finish it with spray paint and of course I could see all my grinder marks, it looked like 💩! A can of Bedliner, problem solved and it has held up fantastic. On the trails and power washer. 👍
