oceanblue2019
Is that a D4 with the twin voice coils? You running them in parallel?There’s quite a bit of awesomeness to unpack here. JL 12” TW3
Set gains with an O-scopeWhat tools are you using to tune the dsp?
i was going to recommend the audiocontrol eta.Set gains with an O-scope
Audio Control RTA that I just bought
TUN software in my Mac For the DSP
Still have a long way to go. It sounds good but I can tell it needs better EQ.
Set gains on subs first since I am running 1500w into two 10s. Now that those are good, I will start with midrange and try to get the widest response so that the voices sound as detailed and clear as possible, then try to dial in mid-bass, then tweeters. I think the bass will have to be attenuated based on what I am hearing so far - my mid-bass, mids and highs are getting a combined 210w each side, my subs 1500w. Learning a lot. Much to my wife’s dismay, this will take a while. She thinks I’m nuts sitting in the Jeep listening to Test tones with a PC on my lap. Then I have to do it again for top on, freedom too off, doors off, etc. I was 100% Willing to pay someone to do it.
yes, d4 run at 2 ohms.Is that a D4 with the twin voice coils? You running them in parallel?
LolReal men run 18" subs. Multiple of them.
Where a single sub costs as much as my entire system....Lol
I guess I'm not real with my measly 10" (sub that is)...
Is each layer cut then glued (can't think of another way but had to ask)? Did you use a CNC and if so can I have the files?
You can move air with area, or with throw, and you took the path less travelledLol
You can move air with area, or with throw, and you took the path less travelled![]()
Very nice work! ImpressiveThere’s quite a bit of awesomeness to unpack here. JL 12” TW3
Where did you put the DSR1, if you don't mind me asking, I did almost the same Focals front with the 4.5 in SBUpdate 2....
Speakers will be Focal Flax Evo separates in the dash using the Metra pods. Soundbar is the coaxial version of the Evo’s.
Everything will run active via the Rockford Fosgate DSR1/Maestro interface and dsp.
