MarkY3130
The steering wheel is an easy adjustment. Loosen up the adjustment sleeve on the drag link and rotate it until the steering wheel is straight. Rotating one way turns the wheel a specific direction. Rotate it the other way to turn the wheel the other direction. Then tighten it back down. All you are doing is lengthening/shortening the overall length of the draglink which is necessary as the vehicle is sitting higher and the draglink connects between the wheel knuckle connected to the axle and the pitman arm/gear box connected to the body. The axle and body just moved farther apart so it pulls the wheel to one side until you adjust it.So we just had a rubicon suspension swapped into our sport today and a few things were noticed.
First, the steering wheel is slightly off to the left and will need to be adjusted. Not sure if that’s an easy task or not. Will probably let alignment peeps do it.
Second, the rear springs appear to be the same height but the front springs appear to be slightly differing heights. They compared the sport springs to make sure it wasn’t an anomaly with the rubicon take offs but they were the same. I gave the shop the part numbers I posted early on in this thread for springs so they were able to sort them out based on that. Don’t remember which was the tall vs short side but relaying the find for what it’s worth.
Lastly, they measured and compared and insisted the 4 sway bar links were identical, the two front lower control arms were identical and the spring perches were identical other than color. I had them go ahead and put the rubicon lower control arms and perches in, but I held the sway links out as spares down the road.
Overall made a nice ride difference and height difference. Pleased and will get the alignment and wheel straightened later this week.
Easiest if someone sits in the drivers seat and tells you when it’s lined up.
