Rubicon vs Moab
Which one should I get?
  • Total voters
    527
IronScott
NW Arkansas
2019 JLU Sahara, 1992 Jeep YJ, 2002 Chevy Silverado
Some MTs have blocks close enough that the grooves will hold snow in them which gives you snow-on-snow traction. In addition to rubber compounds and siping, snow-on-snow traction from retained snow in the treads is a big part of winter tire traction. A lot of MTs have huge grooves for shedding mud and will therefore shed too much snow to allow for snow-on-snow traction. Others will hold enough snow to be decent. But a lot of them are pretty hard rubber compounds in really cold temps and few other than some "hybrids" on the mild end have any siping at all. Siping is key, especially if there is any melting/salt/moisture on the road surface.
Claiming ignorance here, but siping is basically cuts in the tread, right? The picture below is my KM3 with cuts in the middle lugs. Is that considered siping or are they too large?
Jeep Wrangler JL Rubicon vs Moab 3505597C-E593-4057-841D-E7FE57B5F078
Sean L
Sean
North Carolina
All the small little "cuts" in the tread blocks you see on the Wrangler AT Adventure is the siping. This tire is M&S rated but a dedicated winter tire will have much more than this one.
Jeep Wrangler JL Rubicon vs Moab 57332c03-1571-4071-b5d2-58906c962f81_1.0bea339ef85a7c4d7010cc60f1464569
IronScott
NW Arkansas
Thanks. That helps. Mine is M+S rated but obviously very different from what you posted. Not a big deal to me as we don’t normally get a lot of snow - ice is common, though. Just trying to learn.
Sean L
Sean
North Carolina
Ice might pose more of a problem to the KM3 than for other AT tires, but then again its dangerous for just about any tire.
Slowpoke
Columbus, Ohio
22 Mojave & 22 Sport
Yes
Ice is ice. Tire studs or chains will help on ice.
Mjmi69
Cornelius, NC
2019 Jeep Moab, 2019 BMW 335, 2018 Jeep Rubicon Recon, 2018 BMW 435i
Broker/Owner
They have the exact same suspension and the Moab has worse tires. What are you comparing to?
Like I said , I have both the Moab and Rubicon and the ride is far better in the Moab
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Are they both stock? The only thing I can think of is the CV joints on the Moab vs the U joints on the Rubicon.
Mjmi69
Cornelius, NC
Broker/Owner
Yes both stock, night and day on how they drive
mwilk012
Service
What do you mean by that? There should be very little difference, if anything the Moab would be worse off with its KM2’s. Is something wrong with your rubicon?
MarkY3130
Denver
2019 JLUR
He posted above that the 2018 is a JK. I know my JLUR drives way better than my JK did. That’s what the difference is.
Mjmi69
Cornelius, NC
Broker/Owner
Oh I see that now. Why would you even compare those? They’re hardly the same vehicle.
I don’t disagree, just saying
