That's what I figured, these steel bumpers were 392 Rubi take offs bronze hooks, I got at a great price but I want to replace with my red Rubicon tow hooks.I have never had success removing those retainer rings in a manner I could reuse them, they are used to hold the the hook in during the install process before the nuts are put on. I just use needle nose pliers, grab one of the tabs and twist, the ring will snap off.
cool! Swap the red ones over and reuse the washers and nuts, then post pics of the new bumpers on your rig when you’re done.That's what I figured, these steel bumpers were 392 Rubi take offs bronze hooks, I got at a great price but I want to replace with my red Rubicon tow hooks.
Thanks
Did you buy that bumper from a guy in High Point? If so it’s probably the same guy I got the 392 wheels from lol I bought the gold tow hooks aftermarket since he said he already sold the bumpers.Need a little assistance, in the below pictures how do you remove these "retainer rings" and are they reusable? Can they just be replaced with nut/bolts?
Thanks.
Yes I did as a matter of fact, red 392 nice guy. Will do!I’m
Anyway you can try to work them off by taking a flat head and and prying up a side then grab with pliers and try to thread it off counter clockwise. It’s easier to cut it with side cutters and get new retaining washers ( or whatever they are called) should have them at an auto parts store or maybe a hardware store.
Share some pics of how you replace these as my Jeep haven’t arrived yet and I’m interested in how to replace the tow hooks.
Did you have to remove/disassemble any parts other than the retaining washers from the steel bumper to get them out?Got the tow hooks off the steel bumper I purchased now just waiting on my Rubi to show up at dealer to swap out for the red ones from the plastic bumper and install steel bumper. Currently Rubi is riding the rails like a hobo in transit.
Thank you all that replied!
Yes I had to remove the sides of the bumper you remove if you want the stubby look and the torx bolts holding the plate to the bumper that has the fog lights. Once the retainer rings were removed the tow hooks easily lifted out from behind the fog light plate. I will get more pictures soon to show what I did.Did you have to remove/disassemble any parts other than the retaining washers from the steel bumper to get them out?
Did you have to remove the plastic fog light trim covers pieces? I’ll probably go ahead and order some retaining washers, didn’t know if I need those plastic rivets for the plastic trim pieces also. Hard to see what all I need without having my Jeep here lol. Not a big fan of starting a project and needing parts to finish.Yes I had to remove the sides of the bumper you remove if you want the stubby look and the torx bolts holding the plate to the bumper that has the fog lights. Once the retainer rings were removed the tow hooks easily lifted out from behind the fog light plate. I will get more pictures soon to show what I did.
Edit--Looks like you have steel bumper in picture? If so you just need to remove the bumper end caps (all torx 40 bolts) and remove the torx 40 bolts holding the fog light mounting plate, no need to fully remove it. Once you remove the retainer clips from the tow hooks lift up on the fog light mounting plate and the tow hooks are easily removable.Did you have to remove the plastic fog light trim covers pieces? I’ll probably go ahead and order some retaining washers, didn’t know if I need those plastic rivets for the plastic trim pieces also. Hard to see what all I need without having my Jeep here lol. Not a big fan of starting a project and needing parts to finish.
Yes these help a lot thanksHopefully these pics help...super easy to remove tow hooks just a lot of torx bolts and 8 retainer rings per side. I will be happy to answer any questions.
No it is not necessary, I installed my gold set without retainers.Do you need to replace the retainer clips? It seems like it would help with installation but don’t the tow hooks bolt to the frame? I’m getting a rubicon bumper and want to use my black tow hooks.
