Some Random Guy
- Sep 16, 2020
- Washington
- 2022 JL Sport, 2022 Ford Mustang
- Occupation
- Comptroller
I'm finally getting around to posting these.
Rubicon Shocks/Springs and the isolators if you want them, $50. All labelled before I lost track of what was what. From a 4 door with steel bumper and HD package, 3.6L. I think they had under 7,000 miles on them when I did the lift. I have the front sway bar links, but not the rear.
4D Rock Rails $50. Passenger side might be bent from using it to jack up/break beads on tires, if you bring your rig we can test fit it for you before you hand over any cash. I think it has all the hardware, I didn't need to re-use anything.
Tire carrier (no camera) $Free.99 if someone wants the Rubicon carrier. Includes isolators. I've got the mast, but no brake light. I recycled mine onto my new carrier.
I've also got tires at my storage unit. 5xBFG KO2's, but I'll probably post those separate. I'm just throwing the line in here in case someone wants to grab everything rubicon all at once. The tires are dismounted from rims (which are gone), so you'll probably need to know someone to get them mounted. I think major chains don't mount used tires. 3 tires have 7,500 miles, and the others have less. I have them labelled in Sharpie.
