Phenomenon
Both of them look great so I'm having a hard time making up my mind on it. What did you go with (or are planning to)?
stock...why pay $800 ish for an "upgrade" that is the same exact size (both are 17x7.5, only a different look. IMO stock looks better anyways. Not to mention when you go bigger tires you will likely change out to a wider better backspaced rim anyways.Both of them look great so I'm having a hard time making up my mind on it. What did you go with (or are planning to)?
I was going back and forth on my order as well, when I placed i went upgraded, but regret it as I understand how on the edge running 35's is without a lift kit and/or wheel change.stock...why pay $800 ish for an "upgrade" that is the same exact size (both are 17x7.5, only a different look. IMO stock looks better anyways. Not to mention when you go bigger tires you will likely change out to a wider better backspaced rim anyways.
Right? If you have to ask then I wonder why even consider paying that kind of money when they offer no functional advantage. If you absolutely love the option wheels or hate the stock, then perhaps, but even then you have a lot of aftermarket options that wouldn’t cost a whole lot more.stock...why pay $800 ish for an "upgrade" that is the same exact size (both are 17x7.5, only a different look. IMO stock looks better anyways. Not to mention when you go bigger tires you will likely change out to a wider better backspaced rim anyways.
That doesn't answer anything about 35's though... Which is where most of the grey area seems to lie.If you ever plan on putting bigger tires on >35's, I would go with stock and get aftermarket wheels later on.
Yeah but functionally they are exactly the same. Stock/alternatve wheels are skinny and not great for 35s regardless of whether they fit without a lift or not. You are just better going stock and saving your pennies for new wheels if you think you are going to get 35s no matter what.That doesn't answer anything about 35's though... Which is where most of the grey area seems to lie.
