Rubicon Steering & Tire Pressure?
Jeep4Life0112
Kevin
Fort Wayne, IN
2018 JLUR (Mojito)
I picked up a JLUR on Friday and almost immediately noticed the steering issues that others have posted about on here. Seem to recall there being recommendations to air down the tires a bit from their original factory settings as a first step. Currently the dash shows them ranging between 42-40 psi. What is the recommended psi for mostly highway driving? Thanks much.
Deleted member 18624
Guest
Should be listed on the driver door jam but I believe it's 37psi
WXman
Central Kentucky
2018 Wrangler Unlimited
Yes, there are recommendations to air down to spec, BUT, this will not cure the wandering issue. Tire pressure causes improper wear, changes in MPGs, and other things, but it will not make a steering wheel dance left and right to maintain a straight line.
The proper approach if your build date is winter or spring 2018 is to have the PCM flashed with the proper calibrations for your VIN first. THEN and only then if the problem isn't solved you can investigate your steering box. But, the software update usually cures the issue.
JIMBOX
JAMES
FERNLEY NV
2018 HELLAYELLA JLU SAHARA/2016 "STINGER YELLOW" RAM
Tire pressure had EVERYTHING to do with my steering "WANDER" and by dropping it to 30 psi I now have NO DRIFT/NO WANDER/INSTANT FEEL/W NO STEERING WHEEL PLAY--
Now, mines a 2dr and I've heard of 4dr's having other steering problems, but
The front tire air pressure is VERY IMPORTANT to steering action-
W.E.
JIMBO
Chemy350
Atlanta GA
Porsche Sales
Took my JLU Rubicon down to 33 psi, MUCH improved. The tires may wear a bit quicker but I don't care.
Jeep4Life0112
Jeep4Life0112
Kevin
Fort Wayne, IN
2018 JLUR (Mojito)
  • Thread starter
  • Thread Starter
  • #6
Aired down to 37 psi over lunch and instantly noticed an improvement. Thanks everyone for your help!
1995YJ
Vincent
Charlotte, NC
1995 YJ Rio Grande, 2018 Subaru WRX STI, 2018 JL Sport S 3.6L 6 Spd
I’m down to 32-33 on a 2dr sport.
Kadonny
Malvern Pennsylvania
2018 JLUR Manual Trans Front Spacers, 2010 JKU Wrangler Sport
I run 36-37. Note, outside temperature has a big effect on tire pressure so keep an eye on that. I've seen 3-4 psi varying between really hot days and average days.
Rhinebeck01
2018 2dr. Rubi
@Jeep4Life0112
DO recheck you tire pressures with a decent tire pressure gauge in the early morning before you drive the JL and before it gets hot outside.
Real bad idea to be adjusting psi in the afternoon.. "over lunch".
I found that with my Rubi, 36# psi was best overall. ALSO, be sure to telescope your steering wheel toward you so you are not reaching for the steering wheel while you are driving. You want a ben in your arms when steering.
You will notice steering seems to get even better after you get say 500 - 1,000 mile of the JL.
Rhinebeck01
2018 2dr. Rubi
@Chemy350
@1995YJ
I chalk tested, drive tested, etc. and 32 and 33# psi was not as good as 36# .
Steering is overly slugglish lets call it when tires are inflated to 32 - 33#.
JeepJets
San Marcos, CA
2018 Jeep Rubicon
How are people approaching the dealer with this? I just came back from Bullhead AZ and the drive out and back was scary when in the higher temps of 90s. Considerable play in steering of an inch or so. Required driving at 10&2 with a death grip to avoid moving into other lanes uncontrollably. I noticed my PSIs as expected in the warmer temps to rise 4/5psi so was around 41/42 psi when in the higher temps. When I got back to San Diego in the 70s the psi was back to 36/37 and the issue was gone. Lightly able to place the hand on steering wheel and steered the vehicle straight.
WXman
Central Kentucky
I'll put it like this: if you drop your tire pressure 5 pounds and it cures a wandering problem, then you never really had a wandering problem to begin with.
This has been hashed out in countless threads where all five of the tire brands/types used on JL have been tested, and at various pressures, and the true wandering issue stayed the exact same. Which is to be expected, of course.
As far as how to approach the dealership... just tell them that your Jeep wanders all over the road and you have been told by very reputable sources that the calibrations in the vehicle computer need to be updated.
Mine went from two hands on the wheel at all times to a totally different vehicle when I had my PCM flashed in June.
Where the water gets muddy is that people have demanded so many different fixes that what I have heard is Jeep is screwing with the steering boxes at the factory now. So, if your JL is a late build, the software flash may not cure it. This has turned into a real cluster.
Jeep4Life0112
Jeep4Life0112
Kevin
Fort Wayne, IN
2018 JLUR (Mojito)
  • Thread starter
  • Thread Starter
  • #13
@Jeep4Life0112
Thanks for the tip! It was about 90F when I deflated the tires so I will check with an actual gauge tomorrow morning to see how it changed.
JIMBOX
JAMES
FERNLEY NV
I'll just have to assume that you feel that I'm a drunkard/drugeeD, or live in a non-real world--
My post #4 is exactly the REAL DRIVING SITUATION and if you doubt my word, then I suggest you avoid any of my posts, because after driving off-road for over 64 years I have a VAGUE idea of solid axle tire tread and air pressure steering parameters--
If you're not happy with my opinion/ideas/remedies--complain to a MODERATOR and if you're right--BY BY !
W.E.
JIMBO
DanPop
Vermont
2018 Jeep Jl Unlimited Sport S
W.E.
JIMBO
How is your low tire pressure warning not going off? My understanding is anything under 34 triggers it.
You are wasting gas and losing about 20 thousands miles on your tires.
I also think that some people (you for example because of having a 2 door) don't understand what us with 4 doors are going through. We (or I at least) have normal wandering, the issue is moving the wheel what we normally expect doesn't do anything and before we know it we have wandered more than usual. It's that damn 1 inch or so of free play.
And by the way Jimbo, relax, no one's pissing on your Corn Flakes.
PSC Motorsports
