Rubicon Springs on Sahara
Warz2k4
RIC
New York
n/a
Here’s my Rubi takeoff info (I also added a teraflex 0.5” spacer on all 4 corners).
spring info:
Orig.
DF-58 PF-59
DR-87 PR-88
Rubi
DF-61 PF-62 (+3)
DR-91 PR-92 (+4)
Measurements from ground to lower part of fender:
Before After
DF 36.75 38.25
DR 36.75 38.5
PF 36.5 38.25
PR 36.75 38.5
overall very pleased with 1.5” to 1.75” lift and hoping for Rubi takeoff fenders next.
The only trouble I had was getting the Passenger Front spring out as the axle didn’t want to drop low enough to release the spring. I was also replacing the Lower Control Arms with the Mopar 2” lift kit LCAs so I dropped the stock LCA out and the spring just Fell out. It was a bit difficult getting the new LCA in with the Jeep raised in the garage though. After swapping the new LCA on the drivers side and raising the axle up towards normal compression, the New LCA went in much smoother. The only negative effect is that my steering wheel is now an inch or so turned to the left as I drive straight.
Thanks for all the insight and info on this site!
how did you break those LCA nuts loose?
Did you find those rubi springs on this forum?
tatohead55
Blane
Olympia, WA
2021 Jeep Wrangler Unlimited Willy's Ecodiesel
And done. Got everything done today. Rubi swap, .5 spacer, mopar LCAs.
Looks great. I have a 2021 willys diesel. How much front lift did the swap give you ?
Pabst113
South Carolina
2020 Jeep Wrangler Unlimited Willy’s
I went straight to the 1/2” impact gun and they came right off. The springs were found locally through Craigslist’s. The guy had them taken off the day he bought his Jeep.
Warz2k4
RIC
New York
n/a
I just bought a makita 1/2 impact gun , will try it this weekend.
bipock
Newport, NC
2020 Sahara JLU
For those of us who added steel bumpers and steel step bars on a JLU Sahara, I assume this will get us back to factory height unless I add larger spacers? I think I lost about 3/4-1" at all 4 tires. I had originally planned to get the Rubi takeoff and then do all that, but decided it'd be easier to get the weight (or most of it) on there first and then decide on the lift amount I wanted/needed.
jmoreland
Jared
Knoxville, TN
2019 Jeep Wrangler Sahara
Ok we got our Jeep done today. Only ended up using the rear rubicon springs but used all 4 shocks. Did a Teraflex 1.5” spacer in the front and a 1” in the rear. Went with ridge grapplers in 285/70/18 with 1.75” wheel spacers. I think it turned out really well. Here’s some before and after pics.
Greyhound
Knoxville, TN
2018 Wrangler JLU Sport S
Jeep Wrangler JL Rubicon Springs on Sahara B156147C-4EF4-42B1-8D23-A8705208BCE8
Looks good!!! I'll be looking for you on the trails!!
jlang
JDawg
2019 Jeep JL Punk'D Rubicon
Semi-Retired
Looks like a different Jeep. Well done!
Warz2k4
RIC
New York
n/a
This might be weird, but those 58/59's on that Rubicon , have a different spring rate than your Saharas.
Trust me I know, because I remove my 90's rear from my Sahara, and compared it to the Rubicon's..and the Rubicon's spring was wider, despite same length.
I would swap the fronts too..(Do not use the Sahara ones)
pls8508
2019 JL Sahara
Does anyone have experience installing the Rubicon 4xe springs on a JL Sahara? The spring numbers are 3666 and 3674, at least on a set I see, which are considerably higher in number than most at 3661/62 in front and 3591/3592 in back. Gas powered JL’s have one digit higher spring on the passenger side to accommodate gas tank and probably other weights, but that obviously doesn’t apply to the 4xe and the spring numbers are the same. So if the 61/62 and 91/92 combo gives almost 2” of lift and it’s been stated here that every digit gives 1/4” to a 1/2” lift, does that mean this 66 and 74 set will give even more? Could this theoretically give a Sahara or Sport a 3” lift? Thoughts?
JLWarrior
Ryan
Philadelphia
2020 JL RUBICON
Looking to make the Rubicon takeoff swap on my 2019 JL SAHARA. As others have stated I’m looking to get ~1” lift to retain factory wheel well sizing and balance with a set of rubicon 33” tires.
Current SAHARA suspension numbers below.
What Rubicon suspension numbers should I be looking for to ensure a 1” lift?
Driver (Front) - 57
Passenger (Front) - 58
Driver (Rear) - 88
Passenger (Rear) - 89
Odyssey USA
Daniel
Indiana
www.youtube.com
Sahara
61/62 only have my Sahara precisely (seriously measured to the nearest 1/16”) 1”. A 90/91 gave me .750” out back fwiw.
DougM
Doug
Raleigh, NC
2021 Jeep Wrangler Islander
Driver (Front) - 57
Driver (Rear) - 88
My JLU Islander (stock with tow package / hard top) started with:
58 / 59
88 / 89
From other posts, It seems you should get about 1/4"-1/2" per spring number, but don't forget to factor in if you are planning for winch, steel bumpers, etc.
Here is a post you might want to take a look at: https://www.jlwranglerforums.com/fo...gs-suspension-information-chart-matrix.66591/
FWIW, I installed 33" Rubi wheels, shocks, springs, and 1/2" Teraflex level kit. The "new" (takeoff) springs were +3:
61 / 62
91 / 92
(I also added winch/steel bumpers -- final result was about 1.5"):
Jeep Wrangler JL Rubicon Springs on Sahara IMG_3839
(made for a much better ride on the beach):
Jeep Wrangler JL Rubicon Springs on Sahara IMG_3888
