jmcdtucson
- Jerel
- Jun 17, 2018
- Tucson, AZ
- 2018 JLU Sport S
- Vehicle Showcase
- 1
Looks like it just tilted the sway bar up. Shouldn't cause any permanent problem from my understanding.Made a rookie mistake last night while attempting this swap; got some sway bar links with the Rubi suspension and assumed (since I was doing the front first) that the new larger sway bar links replaced the smaller ones... well no, the seller only included the rears and none of them needed to be changed since they’re the same size between the Sahara & Rubicon. Unfortunately that’s what took the longest time and we never got to the rears last night, so this project is on hold till Saturday and my Jeep is inoperable atm. Hopefully I can swap the stock sway bar links back out without taking anything else off as it’s all torqued back to spec, and then the rears go faster than the fronts. Also hope I didn’t screw anything up permanently as there’s a ton of pressure built up in the sway bar now... good news is so far I’ve got over an inch of lift in the front but I’m sure it will settle once complete!
