ODDs
I'm sorry to revive an old thread, but I want to double check a couple questions I have from people who have swapped in the stiffer springs and let them settle a bit.
I'm looking to raise our Sahara to about Rubicon height and take out most of the 1" of rake we have currently due to the Rubi steel bumper.
1) Is the general consensus that each increase in spring number results in a 1/3" lift?
2) To go from Sahara height to Rubicon height one would need to up the spring numbers by 2 (2/3")?
3) The springs are not handed, correct? One could take a spring from the right and move it to the left for a 1 number increase.
4) Can I reuse my Sahara shocks with the new springs? I don't really want the red since I am not trying to look like a Rubicon.
5) It looks like most people are using a spacer up front to take out rake. Could one do that by just using even higher spring numbers?
My springs are:
3658 3659
3588 3589
I'm looking at buying a set off craigslist that have these numbers, which give:
3661 3662 >>> +1.0 +1.0
3590 3591 >>> +0.7 +0.7
However, to take out most of the 1" rake, I am contemplating reusing 3589 rear right spring from our 45k mile Sahara for the driver side, and using the new left spring on the right side. So it would be:
3589 3590 >>> +0.3 +0.3
Leaving me with a 0.3" rake. I don't mind a very slight rake so that it doesn't appear to be a backwards rake from certain views.
Or will it be disappointing to have only 0.3" lift in the back, and I should I just order all new springs from Mopar Parts Masters, and get a new result of:
3662 3663 >>> +1.3 +1.3
Or am I overthinking this, and I should part on the new craigslist springs, and throw on a spacer to level it out, whatever that may be? Thanks
My springs are:
3658 3659
3588 3589
