There appears to be two different front fender height locations on the JL, with some of the Rubicon photos showing the front fenders mounted higher than on the Sahara/Sport models. Not sure how this compares to the JK models. Probably the lower non-Rubicon mounting point on the JL matches closely the mounting point on the JK? It would be the higher mounted JL Rubicon front fenders that would be different from the JK.Are we 100% sure the front fenders are higher on the JL? I thought I saw a side by side JK and it was pretty equal?
As you say, it's going to depend how you use it. The newer diesels are much quieter, so it will be interesting to see. Even the old ones were only louder at idle and much quieter at speed. I high revving gasoline engine is much louder. One thing that is known is that the diesel will require much less refueling, which is about to become a bigger issue for Wrangler owners. I hate going to the gas station, and they are making the tank even smaller on the JL. The diesel will get, depending on your use, somewhere between 50% and 100% more miles on a tank of fuel than the gas engine.I can't wait to see what the diesel take will be on this Jeep. So many of you are totally disillusioned by diesels. I have a 6.7 Cummins in my truck and it's awesome because I tow 30 000# often like at least twice a week and every other day its minimum 15000 to 20000 lbs. But maintenance is so expensive, fuel filters need changing at 16000 miles and cost over $100. Oil is expensive, diesel is more expensive than gas most of the time and the noise, the warm up and fast idles in cold temps, and that's because Cummins has the absolute best diesel out there, least expensive to maintain. What are you guys going to do with the 3.0? its loud, its heavy its totally expensive like $4000 more (BTW, $4000 buys a lot of gas) its slow, it needs special attention for start ups. No one knows how to work on them even the dealers. I know dealers are clueless when it comes to my Cummins. Maybe in the 1500 Ram and the Scrambler, but in the grand Cherokee and wrangler???? I think it's a bad application. Total marketing. In the long run you will pay much more for the diesel unless you keep the car 20 years and go 1 000 000 miles, then it starts to become profitable. But most guys change in 4 years and less than 100 000 miles so all a total waste.
Thatās overly optimistic. You think the diesel JL is getting 35-45MPG !?!One thing that is known is that the diesel will require much less refueling, which is about to become a bigger issue for Wrangler owners. I hate going to the gas station, and they are making the tank even smaller on the JL. The diesel will get, depending on your use, somewhere between 50% and 100% more miles on a tank of fuel than the gas engine.
With no additional features itās $4,770 on the RAM which includes the required $500 transmission ugrade (also required for HEMI), add the features at a higher lever then it hides and even higher $5,070 premium for the EcoDiesel because the HEMI becomes the base at that level and itās even greater of a price difference Hemi->ED than that same portion of the Penta->Hemi->ED of the based model.The upgrade cost you cite, we don't know yet. When I bought the diesel jeep I have now, the increase was indeed about $4,000, but jeep included a bunch of optional features with the upgrade, if you added up (and wanted) those optional features, the additional cost of the engine upgrade was around $1500, but that was twelve years ago.
I don't think the diesel JL is getting 35 to 45 mpg. I think the gas one will get about 15 to 16, and the diesel will get 25 or so depending on how it is set up. Those thoughts are based on my real world experience with the Liberty. I can get 30 in the liberty on pure highway driving, but average less than that in normal driving. The 3.6 gas versions get mid teens.Thatās overly optimistic. You think the diesel JL is getting 35-45MPG !?!
Better to spend that ~$5,000+ premium on an extended fuel tank and guarantee that range with 10-25gallon extended tank, and still have thousands left over to buy fuel.
So, we already know that the EcoDiesel requires a different transmission in the JL so it likely wonāt have the option to hide the upgrade vs the 2 other engines the way they do in the RAM.
There currently isnāt the option to configure an ED in the Grand Cherokee, but as the HEMI premium is $3,295 and itās only $1,950 in the RAM then itās highly unlikely that the diesel Wrangler is going to be closer to $1,500 than $5,000.
Prepare for more realistic numbers on both fuel economy & the cost to acquire, otherwise youāre in for a big shock.
I'm glad they got rid of the lower crash bar and Vacuum pump(Or moved the pump) I'm assuming they are putting more reinforcement in the bumpers themselves. The factory JK plastic bumpers weigh next to nothing. I never liked adding big heavy bumpers on top of the existing crash bars.I am extremly glad to see that it looks like JK bumpers will fit on the JL.
Liberty isnāt a Wrangler, youāre confused as to the contribution of diesel and its ability to overcome air resistance.I don't think the diesel JL is getting 35 to 45 mpg. I think the gas one will get about 15 to 16, and the diesel will get 25 or so depending on how it is set up. Those thoughts are based on my real world experience with the Liberty. I can get 30 in the liberty on pure highway driving, but average less than that in normal driving. The 3.6 gas versions get mid teens.
See? I'm not the only one...I can get 30 in the liberty on pure highway driving
Two things: You know the EPA numbers are higher than real world driving right?Liberty isnāt a Wrangler, youāre confused as to the contribution of diesel and its ability to overcome air resistance.
The EPA numbers for the Pentastar are already posted, not 16 unless youāre city crawling where thereās a gas station every other block, or doing something extreme to it, and then comparing it to your Liberty makes even less sense.
Kinda like diesel owners reporting and hopes also, like 50-100%.Two things: You know the EPA numbers are higher than real world driving right?
Funny you say that. You say you can get 30 in your CRD Liberty but EPA numbers say.......Two things: You know the EPA numbers are higher than real world driving right?
https://www.edmunds.com/fuel-economy/heres-why-real-world-mpg-doesnt-match-epa-ratings.html
Second thing, the way my liberty is set up it is very close to a stock wrangler, except that it weighs more and is slightly more aerodynamic. Because of the higher torque, I can spin larger tires at lower engine rpm than you can with a gas motor and get much better mileage than the gas ones. As I said, I get mid-20's in daily driving. The gas versions get about 16.
I only get it on long highway trips, and there are a few small modifications you can make to it that increase mileage. And I have a 2015 Cummins, so I'm familiar with the modern emission systems. The DEF is annoying...Funny you say that. You say you can get 30 in your CRD Liberty but EPA numbers say.......
EPA estimated fuel economy: 19 mpg city, 24 mpg highway
http://www.trucktrend.com/cool-trucks/1104dp-buying-a-used-jeep-liberty-crd/
But take that overly optimistic EPA number compare it to the overly optimistic equivalents, and they are both overly optimistic.
Having driven 17,000KMs coast to coast with the top open (49% time fully down, 49% sunrider open) far from hyper-miling, I got just over 11L/100KM or 21MPG at normal highway speed 12L/19.5MPG at 10KPH over, and thatās with the less efficient Auto. So comparing highway to highway, the JL isnāt going to be worse at anywhere near 16, unless again you you are doing something more extreme.
You overly optimistic of the diesel, and overly pessimistic of the gas versions, and added cost makes the range argument moot.[/QUOTE
I appreciate all the info you put out here. I actually don't dislike gas as long as they are turbo. I wish they would put out a turbo version of the V6 in the Cherokee. It's very good on the road, but off road you have to rev the crap out of it to get up anything steep.
Yeah, Iām not looking forward to the DEF consumption on our VW/ Audi 3.0 tdi once we get the approved fix installed. Iāve been driving around since we got it thinking, hmm, Iām surprised it doesnāt use more DEF. I sure do like the torque, mileage and range though. Iām no longer waiting to get the diesel JLU, the manual Pentastar is too tempting and I will wait to see what people think of the Wrangler diesel, how much it costs, and see if it is still offered in 4-5 years when a refresh might come along.I only get it on long highway trips, and there are a few small modifications you can make to it that increase mileage. And I have a 2015 Cummins, so I'm familiar with the modern emission systems. The DEF is annoying...
