LHB
- Jan 10, 2018
- south shore, MA
- '18 JLU, Rivian R1S, '99 Cherokee XJ
Here's rear view;
Mostly I just have a lot of conference calls. It really doesn't take much time at all.You've got way too much time on your hands
Great pic. Did you OEM the fuel cover or did it come standard?For reference, here’s how my Sahara turned out with rubi wheels and KO2’s. Purchased from a local forum member for 1,200, already balanced with TPMS. Also, NO dealer necessary to link up new sensors, they picked up new tires on first turn of the engine.
Gas covers are only standard on the rubi's unfortunately.Great pic. Did you OEM the fuel cover or did it come standard?
True; I haven't heard any road noise from these tires. This is with the hardtop on. Could be different topless but I doubt it.He said the tire noise will not be any louder than what is on there now. True? I find that hard to believe but I don't think they would be seriously louder.
Some Saharas are showing up with gas covers. Not sure if it's a mistake or what. Read on a different threadGas covers are only standard on the rubi's unfortunately.
Did you lift this at all or just swap wheels?For reference, here’s how my Sahara turned out with rubi wheels and KO2’s. Purchased from a local forum member for 1,200, already balanced with TPMS. Also, NO dealer necessary to link up new sensors, they picked up new tires on first turn of the engine.
Only swapped wheels. I'll pick up the JPP 2" lift later this year (once the springs issue is straightened out).Did you lift this at all or just swap wheels?
Did you take the pictures on even ground? That could easily make a difference. Here are a couple of other photos to compare...Hmmm... so we both did the same thing and only swapped tires/rims with a Rubicon yet yours seems to sit a bit higher than mine. Odd, I assumed you had done a small lift on yours.
