Rubicon rear steel bumper on Sahara
Jeep1967
Ohio
2019 Rubicon JL, 2008 Sahara JK, 2000 Sport TJ, 1995 Sport YJ
Hi going to swap plastic rear for steel. Any different hardware needed? Any different brackets, etc? I’ve done the front already no problems other than the close out panels were different.
Waxaholic
Alex City, Alabama
'93 Sahara, 2004 Sahara, 2018 JLU Punkin' Sahara
Can anyone share the Mopar part number for the Rear Steel bumper with sensor holes. I ordered a steel bumper from local dealer and it arrived without the sensor holes. They told us there was no such part so we ended up letting them keep it. Now back at square one wanting to finish off the Sahara with all steel bumpers. Thanks.
DrDoom
Dom
Montreal, Canada
JLU 2018
It seems that the part number is (based on ref pic from mopar ):
68295568AC
DHW
Atlanta
2018 Rubicon
Attorney
It drove me crazy too. If you want more detailed explanation pm me. My boyfriend is the handy one and did it for me. I can have him give you more details.
Could you pm me or post how you did this? I'm having the same issue on a 18 Rubicon. Pic attached. Also, I had to rewire the license plate light because the plastic bumper I removed had a female electrical connector while the steel one I installed had a male, meaning with the steel bumper I had two male connectors.
DrDoom
Dom
Montreal, Canada
JLU 2018
Check out thread #22 this is what I did and it worked out very well. As for the connectors I can’t help, mine was a direct plug-in.
DHW
Atlanta
2018 Rubicon
Attorney
I saw yours, but look how much longer your end cap is than mine. Maybe if I got some Sahara end caps it would line up?
As for the connectors, I just cut both connectors off the bumpers and spliced the female end back into the bumper wiring.
DrDoom
Dom
Montreal, Canada
JLU 2018
Sorry, missed the Rubicon part. I believed the steel bumper was a direct fit with the Rubicon and this whole « it’s not fitting thing » was for the Sport & Sahara.
Are those end caps where provided with the steel bumper?
DHW
Atlanta
2018 Rubicon
Attorney
Those aren't the ones from my plastic bumper, but both of mine (steel and plastic bumper end caps) are identical. I also now have a bigger gap between the body and the bumper than I did with the plastic one. Not bad, but noticeably bigger. Same for you?
DrDoom
Dom
Montreal, Canada
JLU 2018
Yes there is definitely a bigger gap... got use to it. Good luck for finding a solution for your end bumper problem.
Jeepznthingz
Under a rock
2021 JLURXR Tuscadero, 2023 JLURXR Reign
68295568AC
Is there a diagram showing the complete front bumper?
tatarin
Russ
Bloomingdale, IL
2019 MOAB Mojito Sky One-Touch, 2015 Lexus RX350F-sport, 2005 Camry SE
I'm gonna be installing the steel bumper on my MOAB today, we will see how it goes, I'll try to post some details later.
EngenZerO
Ozzie
Denver, CO
2019 Jeep Wrangler Moab
I’m excited to see your feedback/details! I’m debating on trying this on my Moab as well.
tatarin
Russ
Bloomingdale, IL
So the install was fairly simple. For the end-caps I ended up cutting off the rubicon ones and bolting them on to the Sahara ones. The alignment is not 100% but pretty good. I’m sure if someone made a braket to bolt up to the outside of the end-caps it would make the fit little more aligned.
