Rubicon rear steel bumper on Sahara
Jarmistead82
Jason
2018 Jeep Wrangler Unlimited
Very nice work, I didn’t think about trying this solution. Thanks, will definitely check this out as I see the misalignment everyday and I’m completely annoyed by it.
Any chance you could snap a pic of the alignment issue? Just curious how noticeable it is. Thanks
Jaysjeepycreepy
Michigan
2018 Wrangler JL Unlimited Sahara
It’s stupid. It’s sad the parts guy at the local dealer now knows me for all the parts I needed to add these bumpers. Finally asked why I didn’t just buy a rubi....have any of you installed the front steel bumper? I was hoping to tomorrow. Is it easier to swap? I felt like the rear bumper took way longer than I expected to part of which could have been because of the sensors.
IronScott
NW Arkansas
Front bumper is easy. Really easy. Hardest part is getting to the inside pair of nuts on each side and that wasn’t super difficult, just a bit of a pain.
DrDoom
Dom
Montreal, Canada
JLU 2018
Did a bracket in wood this am to test my concept. The goal was to re-use the Sahara end cap instead of the one provided with the steel bumper. Worked fine!
Used a plastic cutting board for the final bracket material as its flexible and can obviously handle water very well. Result is great!
Note: You will have to drill a hole in the metal bracket to support the plastic piece that is being used as the finition.
IronScott
NW Arkansas
Outstanding work!
ChattVol
Tennessee
JLU 4 door
No solution so far in regards the misalignment. Still thinking about how to fix this. As for the sensors holes; I decided to cap them for now. Ordered some caps on ebay. Will see how they fit.
Which sensor caps did you buy? Any pics?
DrDoom
Dom
Montreal, Canada
JLU 2018
Received the caps but they were so cheap and didn’t fit properly. I decided to create my own using rounded screws and to paint them. Took some time the bumper needs to be removed to bolt them properly. Now it look great and its solid like a tank!
ChattVol
Tennessee
JLU 4 door
Thanks...I just mounted the bumper and prefer to not have to unbolt it. I'm gonna look for some decent looking caps.
crothrock2000
Northern Virginia
2018 Jeep JL Sahara
Any chance that you kept a copy of the template and can PDF me a copy so I could duplicate? Thanks, Chris
