Rubicon rear steel bumper on Sahara
Kevpro
Jax Beach
Sahara JL Unlimited
So the install was fairly simple. For the end-caps I ended up cutting off the rubicon ones and bolting them on to the Sahara ones. The alignment is not 100% but pretty good. I’m sure if someone made a braket to bolt up to the outside of the end-caps it would make the fit little more aligned.
Jeep Wrangler JL Rubicon rear steel bumper on Sahara 20200823_104334
I have heard others say that they had issue with wiring rear bumper lights from Sahara JL Unlimited to new steel rear bumper. Did you have this issue? If so how did you resolve? Do you have any other details you can share on converting the Sahara JL Unlimited end caps to fit the steel bumper? Was it worth the trouble? Thank you
tatarin
Russ
Bloomingdale, IL
2019 MOAB Mojito Sky One-Touch, 2015 Lexus RX350F-sport, 2005 Camry SE
I didn’t not have any problems wiring up the Oracle reverse lights. I ran the wiring up to the twilight area, where the driver side went to the driver side taillight and passenger side went to the the passenger taillight.
As for the end caps I’m pretty happy with that I did, fitment is not 100% perfect but it’s close.
calvinf1
Calvin
Northeast
2020 JLU North Edition
Just pitching in... made brackets and will be installing the rest today.
calvinf1
Calvin
Northeast
So went through the install over the weekend. Was quite involved as a diy because I had to transfer the back up sensors from my plastic Sahara bumper. Luckily the person that sold me the steel bumper retained every bolt and sensor brackets. I did use the Sahara end caps using the brackets I made in previous thread.
Here are the results (sorry car is a bit dirty). The end caps fit pretty well. Everything else wasn't bad, but did have to drill 1 hole on the metal brackets on each side. Some of the members mentioned the end caps is flimsy which I agree. But after putting on the mopar mudflats, it actually secured the end cap to the inner plastic liner much more and I feel much more confident it can take some abuse.
Pictures:
Slowpoke
Jim
Columbus, Ohio
Moab Silver 2018
Yes
Pictures:
Looks good. Nice work.
Du0377
Bobby
Phoenix, Arizona
2019 Jeep Wrangler JLU Sport S
Medical Student
I am installing the rear steel bumper on my sport s. Is there any mounting hardware I need that may not come with it, or am I able to reuse the hardware off my sport s?
calvinf1
Calvin
Northeast
There will be the mounting brackets that you will need to retain from the sport and move it over to the steel bumper. Obviously the end caps are different and will need to be modified to fit the sports end caps to the steel bumper. Also if you have parking sensors, that will have to be transferred as well. Besides that, there shouldn't be anything additional.
Du0377
Bobby
Phoenix, Arizona
Medical Student
What endcaps? My bumper now is one solid molded piece.
calvinf1
Calvin
Northeast
The end caps that bridge the rear bumper to the rear side fender flares. Your sports fenders will not match the end caps that comes on the rear steel bumper because they fit with the Rubicon flares. This thread has all the information on it.
Du0377
Bobby
Phoenix, Arizona
Medical Student
Gotcha, I see what you mean. I actually installed rubi fenders so should be no issues. Thank you for the info though.
redwhiteandrew
Drew
New Hampshire
2021 Wrangler Unlimited Sahara 2.0T
Pictures:
Jeep Wrangler JL Rubicon rear steel bumper on Sahara 20210614_174048
This looks amazing. Do you happen to have a template you can share? Just thought I'd ask! I'd gladly buy a set from you if you'd sell one!
calvinf1
Calvin
Northeast
Sorry bro I don't have a template. I just traced the pattern based on the Rubicon end caps and just drew the shape with pen and paper. No rocket science really and can easily replicated. I didnt kept those paper pattern I drew unfortunately.
BordenPT
Aaron
Canandaigua, NY
2018 Jeep Wrangler JLU
Did a bracket in wood this am to test my concept. The goal was to re-use the Sahara end cap instead of the one provided with the steel bumper. Worked fine!
Used a plastic cutting board for the final bracket material as its flexible and can obviously handle water very well. Result is great!
Note: You will have to drill a hole in the metal bracket to support the plastic piece that is being used as the finition.
My Sahara endcap looks slightly different than yours. Without the insert in it it is too short to have a perfect line up. I am considering cutting at least a 3 inch off the rubi endcap and use that. If I don’t do it right I would have to buy more.
Jeep Wrangler JL Rubicon rear steel bumper on Sahara B9445CE4-5D64-4816-87C8-30C6BBEA0BBC
calvinf1
Calvin
Northeast
For those looking to do this project (non rubi with real steel bumper), looks like Aliexpress now sells this non rubi style end cap for the steel bumper. I ordered it to give it a try. Will post updated once it's on the jeep.
https://a.aliexpress.com/_mOmGDR4
