Rubicon Front Diff Shavings - What is Normal?
gato
New England
2021 JLUR
2021 JLUR with the full-time AWD D44 axle (axle is all stock, except for G2 Diff Cover).
Jeep has 20K mikes total, 18K since last diff fluid change (when G2 cover installed). About a dozen off-road outings (mostly green/blues, some blacks) and a few dozen front locker engagements. All feel normal.
Changed diff oil today and was amazed at the shavings on the front diff plug (pics) below. No bigger chunks found and oil looked clear and nearly new. Rear garage just the paste and fluid was a bit darker as expected.
Question:
Are these shavings normal for jus 18K miles on front diff between changes?
Jeep Wrangler JL Rubicon Front Diff Shavings - What is Normal? IMG_4971
Jeep Wrangler JL Rubicon Front Diff Shavings - What is Normal? IMG_4972
Thank you. It’s only my second time changing diff fluid, so I don’t know what is excessive or expected.
BUSHRVN
MONTE
ALBERTA
WRANGLER JLU SAHARA HIGH ALTITUDE 3.0
Those look like machining shaving from the manufacturing process more than anything, like it wasn't cleaned out properly.
kah.mun.rah
Merenkahre Jr.
Duat
Unfortunately I would say that is enough to make me want to pull the cover for internal investigation.
  • Like
Reactions: J0E
gato
gato
New England
2021 JLUR
I waited until ~1,500 miles, including some good amount of miles in 4HI (straight line) and locker use off-road, before putting the aftermarket cover on.
At that time there was just minimum metal paste and some small particles (1mm size) in the drain plug. I thoroughly cleaned and inspected the diff - everything looked pristine (no scoring, missing chunks, rough surfaces, etc).
Then 18K miles later I find this.
Honestly, I only changed the diff fluid to see if removing suspended metal from the fluid decreases my chance of getting the locker sensor failure - otherwise, too soon to change it. (or so I thought) :)
gato
gato
New England
2021 JLUR
Anything specifically I should look for? (just eyeball the gears?)
I'm far from versed in what a 20K mile diff should look like.
6.2Blazer
Ohio
2019 JL Sport
If I found that in any axle I would be concerned! Honestly have never done a front Rubicon JL axles but have changed fluid and completely rebuilt several axles in my life and anything like shown in those pictures would concern me.
gato
gato
New England
2021 JLUR
Pull and inspect. You’re not going to feel ok until you do.
Yes. I'm going to drive for Ëś2K miles and pull the cover. This way I can see if it is continuing or was just break-in shavings.
Thing is, other then eyeballing the gears I wouldn't know what to look for :)
toothirtyj
Indy, IN
'21 Hellayella JL Willys, 3.6L/6MT, 4.10's
LE
Also look for more shavings and chunks of metal.
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
4hi straight line on tarmac with full-traction turns?
even in that case i blv the axle shaft takes the brunt and not the R&P gears ?
gato
gato
New England
2021 JLUR
No turns. I just run occasionally on a straight line to get the diff spinning, oil on the gears, etc + did it at break in prior to changing diff cover.
With the full time transfer case it is trivial to momentarily move from 4Hi Auto to 4HI Full Time.
GrayWolf.Overland
Subash
Ah full-time 4wd with CV boots.. ignore my comment :D
Old Dogger
Cave Creek Arizona
That needs to be inspected. Not normal!
6.2Blazer
Ohio
2019 JL Sport
In any case what is shown in the picture is not normal, break-in or not. The best case scenario is that the axle or other internal parts were machined in the factory and they simply didn't clean out the metal filings before installing....basically the chunks were just floating around in side the fluid. That's not good, but also doesn't mean everything is going to explode either. If those chunks were actually worn off or broken off from rotating parts in the diff it's bad.
Tangokilo
Tom
Southwest Michigan
1972 Oldsmobile 442, 2001 4runner, 2010 Honda Accord V6 Coupe, 2011 VW Golf, 1969 Triump T100 MC and 2018 JLU Sport S
Not normal.
