Getmadboy
I’ve been thinking of swapping my stock Sahara 4xe suspension to the Rubicon 4xe suspension for a while now and finally came across a set. The original owner had a Rubicon 4xe with steel bumper, hardtop, and tow package. Here’s pics of the part numbers on the springs.
Front driver 68253667AD
Front passenger 68253667AD
Rear driver 68481302AC
Rear passenger 68481303AB
I’m familiar with working on cars (simple mods and maintenance), but I’ve never worked on suspension before. The install was straightforward and made simple after reading threads on this forum and watching videos on YouTube. This one thread was the most helpful to me, but I’m sure there are others that I may have not come across. It has links to other threads with info and torque values for all fasteners involved with this install.
https://www.jlwranglerforums.com/forum/threads/rubicon-suspension-on-2-door-sport.40700/
I swapped in the shocks and springs from the Rubicon 4xe. I installed the longer Mopar lower control arms (from the Mopar lift kit), longer Mopar sway bar endlinks (also from the Mopar lift kit) to the rear sway bar and moved the stock rear sway bar endlinks to the front. Front and rear sway bars are properly angled up slightly.
I took measurements of the fender lip height directly above and in line with the wheel center cap before and after the suspension swap. My Jeep is a 2021 Sahara 4xe with plastic bumpers, hardtop, and tow package. My wheels are stock Rubicon 4xe 17” wheels and 33” KO2’s, tire pressure set to 34 psi.
Stock Sahara 4xe suspension
Front 37 1/8”
Rear 38”
Rubicon 4xe suspension (immediately after install)
Front 39 1/2”
Rear 39”
Rubicon 4xe suspension (this morning, 12 hours after install)
Front 39 1/4”
Rear 38 1/2”
As you can see, the suspension is settling and hopefully won’t settle any more. I’ll check it again in a few days to see if there is any additional change. The biggest change is obviously to the front, eliminating the front rake my Jeep had and handling felt like stock during my test drive. Overall I’m very satisfied with the upgrade and would recommend it to anyone looking for a mild lift to eliminate the factory rake. I very much appreciate everyone on the forum all the information you share. I hope the info in this thread is able to help someone else.
A few comments I feel are beneficial to note. Probably obvious to most, but good info to know beforehand.
Before:
After:
Front 37 1/8”
Rear 38”
Front 39 1/2”
Rear 39”
Front 39 1/4”
Rear 38 1/2”
- Make sure you start with the rear suspension first so you can move the stock rear endlinks to the front once you replace the rear endlinks with the longer Mopar lift kit endlinks.
- When lifting the front end onto jackstands, lift from the pumpkin and place the jackstand under the driver side frame. Since the pumpkin is off center, you may not get enough lift from your floor jack to get the passenger side onto the jackstand. I had to move my floor jack to the passenger side frame to be able to put the jackstand under the passenger side frame.
- To reinstall the new springs, lower the axle as far as you can without stretching the brake lines. It helps to have a second person push down on the rotor while you slightly compress the spring by hand by pushing up on the spring. This should help clear the lower spring seat without having to use a spring compressor.
- To install the new LCAs, start by securing the rear bolt first (hand tight). Since the Mopar LCAs are a tad bit longer than stock, you will need to raise/lower the axle from the pumpkin in order to align the front bolt hole. I recommend having a second person to slowly raise the axle with the floor jack while you watch the bolt hole until it aligns correctly.
Before:
After:
