jetfixer
james
SC
Wrangler Rubicon 4xe
Just thought some of you would like to see the battery with the trim covers removed. I'm getting ready to install Rock Slide Engineering step sliders & planning out my wire harness routing looks like plenty of room.
Back.
Back trim cover. Pull up to remove.
Right side.
Right side.
Right side & passenger front.
Right side cover.
Right side cover back. Pull up to remove.
Passenger side front
Driver side front
Driver side front
front cover.
Backside of front cover. Pull forward to remove.
Left side.
Left side cover.
Left back side. Pull up to remove.
bodhi
Boston MA
4xe
@jetfixer - I had been planning to remove my back seats, this is great info, when you removed all the plastic battery covers, does it look like it is easy enough to access the bolts you would need to remove to take out the rear seats?
I wanted to make my own version of the goose gear sleeping platform.
jetfixer
jetfixer
james
SC
  • Thread starter
  • Thread Starter
  • #5
it looks like 3 bolts on the front & 5 bolts in the back. It looks pretty easy just bulky.
HungryHound
Rick
TN & FL
1975 CJ-5, 1983 CJ-5, 1987 YJ, 1998 TJ
Man, you really did a number on that thing. I was planning on adding some step sliders after a lift, but that looks like it involves a ton of trim work.
You didn't happen to find anything like this tab while you were in there, did you? I found this tucked in with the battery behind the rear seatback. Was wondering where it's supposed to go.
KarlN
Karl
Sparks, NV.
2021 Wrangler Unlimited 4XE
Real estate Broker
Back.
Right side.
Right side.
Right side cover.
Driver side front
Driver side front
front cover.
Left side.
Left side cover.
Very interesting, looks well sealed too. thanks for posting
LJ_3M121318
LJ
Los Angeles
2021 4xe Rubicon
Wait what do you mean? I've been trying to get my dealer to install AMP research power rails but he keeps saying he doesn't know if it will work and that the only one approved for 4xe is the rock engineering rails. Says something about the wiring. What have you seen is the issue here? In looking at OP pictures I still don't see how rock rails would be a problem, from any brand
jetfixer
jetfixer
james
SC
  • Thread starter
  • Thread Starter
  • #13
I have not seen that in my investigation of the battery.
HungryHound
Rick
TN & FL
I was surprised at how much had to be removed to run the wiring. I was expecting just having to remove the door sills. Looks like it's going to be more work than I expected.
Winjet
