Just purchased my wife a Rubicon 4xe, with the one touch sky roof. anyone know anything about the 4xe. also looking on how to care for the skyroof. any suggestions or comments appreciated.
I donāt see any specific lube recommendations,
Page 447 of the manual:
Washing ā Use MoparĀ® Car Wash or
equivalent, or mild soap suds, lukewarm water,
and a brush with soft bristles. If extra cleaning
is required, use MoparĀ® Convertible Cloth Top
Cleaner or equivalent, or a mild foaming cleaner
on the entire top, but support the top from
underneath.
Rinsing ā Be sure to remove all traces of
cleaner by rinsing the top thoroughly with clean
water. Remember to allow the top to dry before
lowering it.
CAUTION!
Failure to follow these cautions may cause
interior water damage, stains, or mildew of
the top material:
ļ¬ Do not run a fabric top through an auto-
matic car wash. Window scratches and wax
build-up may result.
ļ¬ It is recommended that the top be free of
water prior to opening it. Operating the top,
opening a door or lowering a window while
the top is wet may allow water to drip into
the vehicleās interior.
Good - Its 1ā taller than a standard rubicon, comes with a $7500 coupon for your taxes, and has 200 more ft lbs of torque than the gassers (other than the 392)
Bad - itās heavier than an ICE rub, only Mopar and Rock Krawler have a specific lift out so far. The Mopar 2ā lift only gives you an 1ā
Ugly - The sky one touch is not easily removable and the rear window stays in place naked.
