lsp408
- Li
- Sep 5, 2017
- Knoxville TN
- 2017 JKUS
37 on stock suspension with Rugged ridge Max terrain fender flare
How is the coverage with those flares? I need something wider than stock Rubicon fenders.37 on stock suspension with Rugged ridge Max terrain fender flare
its a little bit wider than stock Rubi flareHow is the coverage with those flares? I need something wider than stock Rubicon fenders.
That looks perfect.. have you flexed out the suspension yet?37 on stock suspension with Rugged ridge Max terrain fender flare
Are you doing anything special to hold your extra spare tire weight?•Nitto Ridge Grappler 37x13.5r17
•No lift
•No rub on-road
•Will rub off-road
•Running at 26 PSI
•No regear needed on 2.0 Turbo (can spin the tires at full accel and have no problem with 8th gear on the highway)
Stock fenders? Did you paint the inner fender section black? Using the stock tire carrier?
Just got the 37’s mounted.
I removed all of the inner plastic from the front and rear fenders. I used the American Adventure Lab High-Line Fender Brace to replace the lights. Lastly, I installed the AAL inner liners front and back.Stock fenders? Did you paint the inner fender section black? Using the stock tire carrier?
This looks sooo good
Application | Wheel Size | Bolt Pattern | Load Rating | Offset | Backspacing | Hub Bore | Lug Nut |
JL/Gladiator | 17×8.5 | 5×127 (5×5) | 2,400 lbs | +25mm | 5.72” | 71.5 | OE |
Good to know!I removed all of the inner plastic from the front and rear fenders. I used the American Adventure Lab High-Line Fender Brace to replace the lights. Lastly, I installed the AAL inner liners front and back.
Thanks for the kind words. It looks better with the soft top.
can i ask what kind of roof rack is that? thxso is anyone else thinking of making this a long term solution? it looks like these will rub offroad...
i've removed the inner fenders front and rear. need to flex it out and see how much trimming is needed in the rear. the front looks like it might ride as is.
anyone tried to wheel on 37s and stock height??
very nice and clean. can i ask the total height of your Rubi? thx•Nitto Ridge Grappler 37x13.5r17
•No lift
•No rub on-road
•Will rub off-road
•Running at 26 PSI
I used the Mopar tailgate reinforcement and upgraded tire carrier. There was enough room for the 3rd light, in my opinion. I don’t have many pics with the 37s installed.Good to know!
You are using the stock tire carrier too?
Also if you have more photos of your Jeep can you please post them? Would love to see the different angles of it
