Rubicon 37s no lift
MojitoJLUR
Detroit, MI
2018 JLUR Mojito
Is it possible to drive, not off road, without rubbing until my lift is delivered and installed? They'll be installed on the stock wheels.
AggieJeepGuy
NW AR
2018 JLUR (replaced 2007 JKUR); 2016 Durango Brass Monkey edition; 2011 Expedition; 2002 Trans Am WS6 6spd
Yep, doing it right now on 12.5s no spacers ... thinking 13.5s would likely be a bit more problematic. Every now and then if I turn full right might get a front tire rub or if I turn fast into an entrance with a decent elevation change vs the road I might get some rub on the rear inner fenders. About to swap out for Artec rear inners so that should go away. Will caveat the front by saying I had installed Artec front inners before the 37s so may be some advantage there.
  • Like
Reactions: J0E
MojitoJLUR
Detroit, MI
2018 JLUR Mojito
Awesome, thank you!
aug0211
Ohio
JLUR Turbo, JLUR 4xe
I've been doing it for a month on 37x13.5r17s. No lift and no rubbing on-road.
Off road, you will definitely rub - but on road it has been fine for me. Mix of city/suburban/highway driving and truly no issues to report.
MojitoJLUR
Detroit, MI
2018 JLUR Mojito
Ok really appreciate it. The wife said no 37s or lift until she gets her Jeep. But I just sold my 33s so was hoping I could just run the 37s for a little bit so I'm not in the doghouse too much
Solidaxle
Kevin
Beautiful Ventura county California
2019 JL 2 Door Rubicon
aug0211 What size wheels are you running and what back space ? , Does anybody have any pictures of 37’s on stock Rubicon wheels and no lift. Thank you
MojitoJLUR
Detroit, MI
2018 JLUR Mojito
@AggieJeepGuy Would you mind sharing pictures of your jeep??
metalhead
Kevin
Ks
'18 Rubicon Unlimited
•Nitto Ridge Grappler 37x13.5r17
•No lift
•No rub on-road
•Will rub off-road
•Running at 26 PSI
•No regear needed on 2.0 Turbo (can spin the tires at full accel and have no problem with 8th gear on the highway)
What wheels are those? Looks good!
AggieJeepGuy
NW AR
Next Venture Motorsports
