RUBICON 35s No Lift - Fuel Beast
northbcjeep
Rod
British Columbia, Canada
2018 JLU Sahara
Would love to see some pics of Fuel Beasts on an 18 JLUR bright White. Love these wheels though.
Mopar Lift is done, Fuel Beast wheels arrived today, and I'm going to be installing 315/70R17 on my white Sahara on Monday. I'll post a pic when I'm done.
ArkieJeep
Drew
Fayetteville, AR
2018 Jeep Wrangler JL
No lift in this picture.
JL Pilot - this is exactly the look I'm going for - nice work!
I have a Sahara with stock wheels, 1.5in Traxda level kit, 285/70/18 Nitto RGs - these measure out at 34in x 11.5in. The outside edge of the tire is flush with the outermost portion of the fender. I would like to size the Fuel Beast Wheels so that the outside edge of the tire is positioned like your setup - about an inch or so beyond the fender. I'm trying to figure out if I should get the +20 offset vs the -12 offset.
Wondering if the +20 offset is adequate or if I need more offset since its a smaller tire than your 35x12.5. I've read on the forums that the stock Sahara offset is +44 but I cannot confirm (anybody know for sure?). So thats a difference of 24mm which is 0.94in. So thats how far "out" the +20 offset Fuel Bests would position my tire from the current position. And for the -12 that is a difference of 2.3in moved "out" .....is that correct? Am I reasoning that appropriately? Anyone have any input?
JLU Pilot
Chad
Lake Elmo, MN
Granite JLUR , 17 F350 SD CC, 17 Camaro 2SS Conv 50th, 60 F100
Hi Drew,
Your numbers look to be correct. +20 offset will move the tire out .9" from stock (+44) and -12 would move it out a bit over 2". This offset calculator helps confirm.
http://www.rimsntires.com/specspro.jsp
ArkieJeep
Drew
Fayetteville, AR
Hi Drew,
Also, Discount Tire is telling me the +20 Beast will not fit - it’s not a 5x5 lug pattern, it’s a 5x150. Did you encounter this issue? They said the only 5x5 lug in 18x9 comes in -12 or 0.
You think yours sticks out about an inch past the fender?
JLU Pilot
Chad
Lake Elmo, MN
If you look back through this post on page 4 you will see pictures I posted showing the fit on my Rubicon. Yes the sidewall sticks out about an inch past the fender but not much of the tread hangs out which I like so it doesn't throw as much debris at the paint. You will also find a post on page 6 noting that Fuel Offroad doesn`t even list the 18x9 5x5 +20 on their site which is likely why Discount can't locate the correct rim. Search for this part number online, D56418907357 and you can find sites selling the same rims I purchased. They are indeed 5x5 (5x127) +20 offset 18x9.
ArkieJeep
Drew
Fayetteville, AR
Ended up going with the 20x9 +1 offset and I am highly satisfied. It gives a virtually identical look as yours: moved 1.7in out vs 1.5in.
Thanks again for your help - these forums have been invaluable!
CTTommy
Tommy
18 Rubicon
Finally got Fuel Beast Wheels on my JLRU. 17x9 -12 offset. Stock KO2 tires and no lift. I'm planning on going up in tire size later on when I add a lift but I was shocked at the difference just the wheels made. Even the stock tires look bigger on the wider wheel with the -12 offset.
CTTommy
Tommy
18 Rubicon
Do you have any pics of the front straight on?
ECHO
Craig
Pennsylvania
2-Door JL Rubicon - Black
Retired Air Force - Currently in my Dream Job
Looking Good!!!! Like your choices in upgrades
smithrd65
San Antonio
2018 Jeep Wrangler Rubicon Unlimited JL. BMW Z4 35is, Tesla Model X90D, Chevy 2500 LTZ
Looks great.
Mikey232
Phoenix, AZ
2019 rubicon
35x12.5x18- Fuel vapor wheels and Toyo rt tires. 2in lift is coming soon.
giffordt
Troy
Massachusetts
2018 JL Unlimited Rubicon
Installed yesterday...20x9 Fuel Vapor (Matte Black) with a +1 Offset. Tires are 35 12.5 20 GoodYear DuraTrac's. Tire pressure was set at 38psi. Raised the 3rd brake light to the top position and the spare (in it's factory position) does NOT rub on the steel bumper. So far, so good.
Quadratec
