Any update on the MPG? I am looking into the same tires, how is the handling? Are you lifted? Thanks.
I havent looked at that yet, this week ill keep an eye on it
Around 14mpgAny update on the MPG? I am looking into the same tires, how is the handling? Are you lifted? Thanks.
Thanks, that MPG seems really low, do you know how much you were getting before the new tires?Around 14mpg
Handling is really good.
Ive just Installed a 2.5" lift, havent noticed mpg changes
I just put 35" Nitto Trail Grapplers on my new JLUS with the 8spd auto.. I had the vehicle for about 1.5 weeks and was getting around 22.5 avg. With the 35" tires on a holiday weekend in heavy traffic I was getting 17.5.Thanks, that MPG seems really low, do you know how much you were getting before the new tires?
His wheel/tire weight is 97lbs as per internet specs. Add to that the extra 2/10 inch width due to the 315 size and you can expect mpg to drop close to 4 mpg.Thanks, that MPG seems really low, do you know how much you were getting before the new tires?
I mostly drive rural roads, 60mph. On my C rated 35's (ko2) I get exactly 20mpg.I'm lucky to get 20mpg highway on the stock 33s! I guess another factor that comes into play with MPG is how fast you habitually drive. I've noticed there is a big difference between 60 mph and 75 mph.
Mine fit fine, not obstructing the brake light. I did have to extend the bumpstops to rest against the spare.Do the 35's have any issue in the spare location interfering with the third brake light?
You have no rubbing issues with a +20 offset?View attachment 53613 I obviously love the look of your Jeep and wheels but I wanted to keep the sidewall height the same as the stock Rubicon tires. I went with 18x9 Fuel Beast in +20 offset to not have too much tire hanging out. Wrapped them with D rated 35x12.5 Duratracs. They stick out about an inch which I like.
