Rubi springs - longest shock without unseating springs?
Nick p
Nick
Uk
Jeep Wrangler, Land Rover
The more the shock is inclined the more travel you can get. Obviously it reduces the effectivness of the valving and therefore needs to be valved differently to a vertical setup.
Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
All right AnnDee, now you got me thinking. Every other vehicle like a Ford ranger or my rzr , the shock travels less than the actual tire. On my razor it has 16 inches front travel and 18 inches rear wheel travel. The front shock is an 8 inch stroke and the rear shock is a 12 inch stroke. So the rear is a 1.5 motion ratio. 1.5 wheel travel equals 1 inch of shock travel. 12 inch shock gives you 18 inches of travel.
I just put my tape measure on the rear Jeep frame and it’s 5.75 inches to the bump stop pad. And I marked the shock. I’m going to jack up the frame and see what it does.
Glamisfan
Shit. 4 inches oh spring travel down word anyways equals 4 1/8 of shock travel.
AnnDee4444
Earth
Jeep
Yeah, it was a surprise to me too when I first realized that. I was used to double A-arm and McPherson struts where the shock and spring move less than the wheel, but a live/solid axle is a little different.
@Glamisfan thanks for actually checking, it doesn’t look like the real world results are as extreme as my calculations.
CptFloridaMan
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
A lot of good info here, thanks @Glamisfan
I'm still gonna be researching and the next time I do my rotation I'm gonna mess around with the rear axle and see if the springs start wanting to pop off. When I did the swap to rubi springs I didn't really think of it, but I don't recall dropping the axle too far to even install the springs.
blnewt
New Mexico
Great info in this thread, this pic scared me a little though
Glamisfan
Me too. But the spring was in so it wouldn’t fall too far........
Caymanedge
North Coast
2020 JLUR
There are a couple measurement you can do before you make a selection.
Shock length at rest center to center.
To get more shock travel the shocks get longer. So you can't just pick one with more travel. If it's not centered at rest you will be limited on one side of the travel. Find one that centers up for your length and see how much travel you can get.
Distance between bump stops F/R.
The upper factory bump stop compresses, not sure how much unfortunately. At stock you will have like 4.5" of travel in the front and 6" of travel in the rear, plus compression. This will limit the spring compression and ultimately the shock compression, giving you the total travel. You can add some lower bump stops if you need to limit the travel too.
I have done a ton of research on this and found that the guys at Accutune in CA are awesome to work with. They have a set-up sheet if you really want to dig into the details, plus they can valve the shocks for your liking if you don't go for adjustable shocks.
CptFloridaMan
CptFloridaMan
Gabriel
Miami
2018 JLU Sport 2.0
So i’ve got a theory since I haven’t had the time to measure out the jeep.
Knowing that the falcons are about as long as the fox 2.5s… in theory the fox 2.5s for 2in lifts should be just fine when drooped out on stock rubi springs.
Not sure how good of an idea it would be to run them slightly longer and maybe throw in small a spacer to get it lifted so that the shocks are about 50% extended.
CompressedExtendedTravel
OEM Rubi front15.5723.6258.055
OEM Rubi rear17.5268.5
Falcon 3.3 sp2 0-1.5" front16.226.610.4
Falcon 3.3 sp2 0-1.5" rear 17.528.410.9
Fox 2.5 DSC(2-3) Front16.3426.5110.17
Fox 2.5 DSC(2-3) Rear17.4328.611.17
Tri-City Jeep
