Rubbing issues with 315/70R17 Tires
lalalofsky
Ben
Lawrence, Kansas
2020 JLU Sport
I am about to pull the trigger on some 35s and want to make sure I’m not going to rub on either my LCA or Sway Bar. Currently I’m running the stock 31.5 on stock wheels. I installed rubicon suspension and fenders And front bumper.
My understanding is that I need backspacing (i dont want to get spacers) to push my tires out away from my components, otherwise ill rub on stock rubicon or stock sport wheels. Is that correct?
I am in the market for wheels And tires i suppose, but I want to be sure that I dont rub on my setup. I know the rubi axles are wider, which is why stock wheels and 35s work, so maybe ill win the lottery and buy a set. Until then, I can only hope.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
You can adjust your steering stop bolt
Also take a look at 35x11.5 tires instead
zeebo56
Zee
los angeles
2020 jeep wrangler unlimited sport
yeah steering stop bolts are easy to adjust, takes a few min. I had to do it with the 37s I put on my sport even with the 4.5 backspacing wheels.
LSguy
Ohio
2021 Willys
What did you rub with that setup? I'm 37s on a willys, stock wheels no lift and 2 inch wheel spacers and I don't rub anything at full lock without adjusting steering stops
zeebo56
Zee
los angeles
The tire would rub the LCAs at full turn right/left.
