RS7000MT monotube shocks for the JL
Thread Status:
Not open for further replies.
  1. RanchoShocks
    RanchoShocks Well-Known Member
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Specifically engineered for the Jeep Wrangler JL to provide the handling, control and performance expected from Rancho® RS7000®MT shock absorbers. These shocks provide enhanced stability over stock twin tubes by reducing body roll in evasive maneuvers and tight turns. These shocks feature a high-pressure gas charge that separates the unit’s internal oil and nitrogen to provide additional spring rate. This helps to maximize damping response that dissipates heat for better control.
    To further enhance ride control characteristics, Rancho® RS7000®MT Monotube Shocks include a hydraulic lockout to cushion the impact as the vehicle suspension is fully extended. These shocks are available for the Jeep Wrangler JL and are equipped with our DRS technology. Developed exclusively for the Jeep Wrangler JL, DRS Technology is a unique internal system that includes a precisely tuned metal spring and fortified interior construction to provide additional control, reduce body roll and prevent rod overextension inside the shock.
  2. Arterius2
    Arterius2 Well-Known Member
    First Name:
    Jerry
    Vehicle(s):
    JLU Sahara 2.0L
    Dec 29, 2018
    Vancouver, BC
    2,224
    Liked:
    2,532
    How do these compare to the 5000 and 9000 series shocks?
  3. OP
    RanchoShocks
    First Name:
    Vehicle(s):
    2013 JKU
    Oct 16, 2016
    CA
    286
    Liked:
    139
    Since they are a high pressure nitrogen gas charged shock they will ride firmer.
    If you have been on our RS9000XL at a higher setting similar to that.
    Both the 5000X and the 9000XL will ride "softer" in general.
    But many like a firmer, more responsive ride feel.
  4. Robs JL
    Robs JL Well-Known Member
    Vehicle(s):
    2018 JL Sahara
    Apr 26, 2019
    los Angeles, CA
    157
    Liked:
    65
    Will rancho produce an adjustable steering stabilizer for the JL?
  5. OBJLU
    OBJLU Well-Known Member
    First Name:
    Henry
    Vehicle(s):
    2018 JLU Rubicon
    Jul 23, 2018
    Los Angeles
    127
    Liked:
    47
    Question, I have the 2 inch coil springs with .75 inch spacers, am I safe to use the 3.5 inch shocks?
Loading...
Thread Status:
Share This Page
