RV Wrench
- Paul
- May 31, 2019
- West Richland, WA
- 84 Cherokee, 93 Wrangler, 19 Wrangler
Just installed a set of Rough Country Vertex adjustable shocks.
My rig: 2019 Rubicon 2-door, 35" tires with no bump stop spacers.
Shocks installed:
-fronts: 68008
-rears: 69009R/L
These are for 2-3" of lift.
These shocks will extend your droop by about 1.5" at both the front and rear of the vehicle, without the need for extended bump stops. The shocks bottom out after about 1.5" compression of factory bump stops. Total travel for the Vertex front shocks is 9.5" and rear shocks 10.5".
These shocks have a very large shaft. That much area combined with the high reservoir charge lifted my rig 1" at every corner.
Ride quality:
Holy cow, someone did their homework.
Rebound: I had serious issues with the (too) soft rebound of the factory shocks. In sand dune whoops, the suspension would pogo bad and lead to bad bottoming issues and bucking. In the trees on the trail, it would weeble-wobble pogo side to side through the ruts and roots. The rebound on the Vertex shocks is MUCH more controlled, and leads to an overall ride that gives great confidence at higher speeds and makes the nasty go away. No more bucking.
Compression: Good so far. I have only really tested it on level 1 (softest setting). Better bottoming resistance than stock, yet softer on the high speed (small jarring bumps. Think washboards). Makes most of them disappear. I haven't tried it on any harder settings, but I am really looking forward to pounding them in the sand dune whoops.
Fit and finish:
Perfect fit. The rears bolt right in. The fronts need to have the springs removed to install the reservoir holding brackets. It would have been much easier not to have to remove the front springs, but it tucks the reservoir away nicely, while still leaving the adjuster in perfect reach. I love the easy swivels they used on the remote reservoir hoses. Totally top-notch.
Finish is great quality. I am a little concerned about how well the zinc coating on the shaft and spacers will hold up to the winter de-icing corrosion, but we'll see in a few years how that goes. Would have preferred stainless hardware for longevity.
I have no other high end Jeep shocks to compare these to, but will say these were impressive out of the box. I have a pretty good background with supermoto/dirtbike/streebike suspension though.
Shocks installed:
-fronts: 68008
-rears: 69009R/L
Ride quality:
Fit and finish:
