Jerrybizzle
Mine isn’t even close and have never heard it hitting.Anyone else having a problem with front drive shaft hitting the bracket?
Translation....sales margins/demand doesn't currently justify repackaging it and selling the gas tank separately.I messaged them asking that as that’s what I would have preferred. Here’s there response. It’s pretty dumb as their jk gas tank skid isn’t $400 but because it’s a jl it isn’t available and would be $400. Here’s there reply.
After reading many threads.....I tend to agree with your idea's on the gas tank skid......at least for my purposes. I decided to go light......because that is the way I wheel. I don't recall ever seeing a thread on someone with a punctured gas tank. (?) And......I do more "sploring" than rock crawling.I’m not opposed to a gas tank skid, but the Jeep comes with one. I figure I can just replace it if it gets messed up. I guess it depends on how hard it is to install. I don’t want to drop the tank, but I’d think an add on would lose quite a bit of clearance.
I did. I installed the Mopar 2” lift and it solved the problem. Only other way to fix it (that I know of) is an upgraded driveshaft.Anyone else having a problem with front drive shaft hitting the bracket?
How bad did it rub? Was it at full flex or what?I did. I installed the Mopar 2” lift and it solved the problem. Only other way to fix it (that I know of) is an upgraded driveshaft.
It wasn’t full flex. I’m in Pennsylvania, so PennDOT sucks and some of the bumps are killer, but even on the smaller ones, as long as I was at speed, hit the bump with both tires, I would hear (and feel) it hit.How bad did it rub? Was it at full flex or what?
is your sahara awd? i wonder if that has anything to do with it.It wasn’t full flex. I’m in Pennsylvania, so PennDOT sucks and some of the bumps are killer, but even on the smaller ones, as long as I was at speed, hit the bump with both tires, I would hear (and feel) it hit.
What did they charge you for it with install? Good to hear no more rubbing.The lift solved the problem of the DS hitting the bracket. I had the mechanic check to see if I needed to upgrade the DS. He said the lift solved the issue - and it did. I still may upgrade the DS later on, but only after I pay off the 2” Mopar Lift the Dealer put on. lol
