Rough Country JLU 3.5in coil kit
Rough Country Suspensions
Rock Sponsor (Level 1)
Ryan
Dyersburg, TN
www.roughcountry.com
2018 Jeep Wrangler Sport, 1998 Jeep Cherokee
Sales Supervisor
Introducing the Rough Country 3.5in JLU lift kit!
Jeep’s JL Wrangler model is an impressive overhaul over previous designs, with modern appointments and considerably more power. Put the finishing touch on your new JL with enough clearance to easily run 35x12.50 tires with Rough Country’s 3.5in Suspension Lift! This easy-to-install kit offers a total transformation in the look of your Jeep while maintaining a smooth, factory-like ride. Instantly gain an aggressive look and commanding stance that will truly set your JL apart from the pack!
Rough Country’s 3.5in Suspension Lift includes front and rear coil springs with a linear coil rate that promotes incredible handling while retaining more lift height under load than other designs! For an impressive ride quality both on and off-road, this kit also includes Rough Country’s nitrogen-charged N3 shocks. These 10-stage variable valving shocks feature a durable 18mm spring loaded piston rod, huge 54mm shock body, and reinforced seals for a long lifespan of smooth performance. A set of control arm drop brackets allow you to retain the factory arms at the proper geometric angle for great handling and a smooth highway ride. Better still, this kit features sway-bar links, bump stops and a front, adjustable forged track bar which helps keep your axles tame even under demanding off-road action and is easy to adjust on the vehicle.
Jeep JL models lifted 3.5" or taller are prone to driveshaft damage at full suspension droop. The factory shaft does not have adequate clearance once lifted and will cause damage to the Rzeppa joint if the driveshaft spins while the suspension is fully flexed or articulated. Rough Country’s Stage 2 Kit includes an aftermarket front CV driveshaft to eliminate this issue and allows you to take advantage of the full travel potential of your lifted Jeep JL! Rough Country’s Jeep JL 3.5in kit features an easy installation process with only light drilling required for an easy, no-fuss assembly and includes a Lifetime Replacement Warranty for the ultimate peace of mind!
Features
  • Easy Installation
  • Increased Ground Clearance
  • Includes upgraded CV Front Driveshaft
  • Great handling and smooth ride quality
  • Includes a Forged Adjustable Track Bar
Notes
- IMPORTANT
  • Fits 4-Door models ONLY
  • Does NOT fit Rubicon models
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
Features
  • Easy Installation
Notes
- IMPORTANT
Is there going to be a kit for the JL Rubicon unlimited?
MAKO-FL
Ormond Beach Florida
2021 Rubicon JLU
Just out of Curiosity, It says won't fit Rubicon Models. Why won't it work with Rubicons?
