Rough Country 2.5in Spacer lift
  1. TTEChris
    TTEChris Well-Known Member
    First Name:
    Vehicle(s):
    2018 JLU Rubicon & Sport(Wife)
    May 17, 2017
    Houston, TX
    2,036
    Liked:
    4,466
    Garage Profiles:
    It really depends on the "actual size" of the tires you are going with. I had a customer with a 315/70r17(Slightly smaller than a 35") and it BARELY fit... As in sitting on the bumper when closed. If the tire was .25" taller it wouldn't have worked.
  2. JeepingKarla
    JeepingKarla Well-Known Member
    Vehicle(s):
    Ram 2500
    Feb 14, 2018
    NC
    54
    Liked:
    Occupation:
    Mothetfucker
    What shocks can I get to avoid using the extension brackets ? Do you offer any ?
  3. Cody6597
    Cody6597 Well-Known Member
    First Name:
    Elliott
    Vehicle(s):
    Jeep JL Unlimited Rubicon
    Mar 18, 2018
    Houston
    249
    Liked:
    342
    Garage Profiles:
    Received my lift today but now thinking of install myself. Unfortunately I would be doing this alone? Any reason I cant do this in my garage with the proper tools? Hate to get it apart and then need help.
    Thanks.
  4. TTEChris
    First Name:
    Vehicle(s):
    May 17, 2017
    Houston, TX
    2,036
    Liked:
    4,466
    Garage Profiles:
    If you have all the tools I don't see why not. PM me if you need help, and I will give you my phone number.
    You can txt me throughout the day if you get stuck.
    Jeepneck and Cornfed like this.
  5. Cody6597
    First Name:
    Elliott
    Vehicle(s):
    Mar 18, 2018
    Houston
    249
    Liked:
    342
    Garage Profiles:
    Greatly appreciate that man!
    TTEChris likes this.
  6. Nick80
    Nick80 Well-Known Member
    First Name:
    Nicholas
    Vehicle(s):
    2018 JLU Rubicon & 2010 Jeep Commander
    Dec 23, 2017
    VA
    86
    Liked:
    136
    Can the bump stops be DYI modified to work for 37’s
  7. TTEChris
    First Name:
    Vehicle(s):
    May 17, 2017
    Houston, TX
    2,036
    Liked:
    4,466
    Garage Profiles:
    The rears can easily be flipped vertical for 3", and the fronts order some 3" JK bumpstops or large fender washers and a longer bolt. Most of the JK bumpstops require you to drill a hole that Jeep conveniently pre-drilled for us on the JL. :like:
    Jeepneck and Nick80 like this.
  8. Nick80
    First Name:
    Nicholas
    Vehicle(s):
    Dec 23, 2017
    VA
    86
    Liked:
    136
    Are you running your 37 spare on the carrier?
  9. TTEChris
    First Name:
    Vehicle(s):
    May 17, 2017
    Houston, TX
    2,036
    Liked:
    4,466
    Garage Profiles:
    I am, but I have a ROAM rear bumper/carrier.
    eciaccord and Lindag8r like this.
  10. GoGators353
    GoGators353 Well-Known Member
    First Name:
    Patrick
    Vehicle(s):
    Jeep Wrangler
    Apr 8, 2018
    South Florida
    141
    Liked:
    136
    Just wanted to share that I did the install last weekend and while I have done a lot of work on cars, I've only lowered them, not raised them. That being said, the instructions included were the best I've ever come across and the install was pretty straight forward. That being said, it took be WAY longer than the 2-3 hours in the instructions but I was expecting that from this thread and having no lift access. I think it took me around 6 hours but it seemed longer because I had to drive afterwards so I wasn't consuming any beer, which really slows things down.
    Most of the time spent was on the front, where I started, trying to figure out all the pieces and what I had to take apart. Then I wasted a lot of time raising jack stands and lowering the suspension to get the springs out. Once I figured all that out, the other corners went much quicker.
    Ride seems really good and the steering was so so much better than stock with the stock AT Sport tires but once I put the Rubicon wheels and tires on, I was back to drifting all over the interstate, which blows. My wife is terrified to drive this because of the steering so I'm hoping RC steering stabilizer will help out but we shall see.
  11. OP
    Rough Country Suspensions
    Rough Country Suspensions Well-Known Member
    Rock Sponsor (Level 1)
    First Name:
    Ryan
    Vehicle(s):
    2018 Jeep Wrangler Sport, 1998 Jeep Cherokee
    Feb 8, 2018
    Dyersburg, TN
    111
    Liked:
    142
    Occupation:
    Sales Supervisor
    The steering stabilizer may bandaid the wandering but it not a correct fix for what you are describing. I would take it to a legit offroad shop in your area and have them look at your alignment. You may need some minor caster/toe adjustment to get the driveability you are looking for. Steering/alignment that is setup correctly will not need a stabilizer at all.
    oceanblue2019 likes this.
  12. GoGators353
    First Name:
    Patrick
    Vehicle(s):
    Jeep Wrangler
    Apr 8, 2018
    South Florida
    141
    Liked:
    136
    Thanks for the suggestion, I should find a specialized place. The day I bought this car, I left the dealer, got on the highway and immediately turned around and told them something was up. They went over it, drove it, etc and said it was normal Jeep. I read in the huge thread on here that your stabilizer helped the terrible drifting these have so I'm hoping it will help.
  13. Mratner
    Mratner Member
    First Name:
    Michael
    Vehicle(s):
    Jk sahara
    Apr 9, 2018
    Boston, ma
    Liked:
    24
    I need your opinions. I'm hapy with the stock JL Rubicon tire size. You think adding the 2.5 lift will look good with everything else the same or will it feel too tall in contrast to the 33s?
    Also my JK 2.5" lift was a teraflex with springs. I missed the factory smooth ride.
    Does this 2.5 spacer lift affect ride AT ALL? I mean more than 2%. please be honest!
    Thanks guys!
    mcclain likes this.
  14. Nick80
    First Name:
    Nicholas
    Vehicle(s):
    Dec 23, 2017
    VA
    86
    Liked:
    136
    Do I need to have an alignment after the install? I’m also planning 37’s at the same time.
  15. mcclain
    mcclain Well-Known Member
    First Name:
    Hunter
    Vehicle(s):
    2018 JLU - White
    Feb 11, 2018
    Austin, Texas
    82
    Liked:
    98
    I like the way mine drives with the lift, but that being said, I'm not going to blow smoke and say it didn't effect the ride at all. I will say though it isn't bad at all, and I actually prefer it over the factory ride. It isn't quite as responsive, but I would say 95% as responsive, it handles like a Jeep, but a much nicer version, head and shoulders better than the ride after a lift on the JK. I put the steering stabilizer in and I drive alot of Highway miles, so far I've been on about 5- 4 hour road trips since it has been lifted and I am still really pleased. Ready for the superchip to come out though.
Loading...
Share This Page
