Rough country 2.5 lift pics / reviews
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
From the ground to the soft top, exactly how tall is your Rubi?
Sorry, my Rubi no longer sits at that height (different suspension and bigger tires) otherwise I would be happy to measure it for you. :beer:
ebelp
Upstate NY
JLU Rubicon (bright white)
For those that installed the spacer lift kit themselves, was it necessary to disconnect the driveshaft from the front axle like they describe at the very beginning of the instructions? Other spacer lift kits don't have this step, so I'm curious if (and why) anyone else did this step.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
You don't have to, but removing the 4 bolts does make it a little easier without putting too much stress on the joint housing on the transfer case side. I've swapped springs without disconnecting it a few times, but made sure the driveshaft was not resting on the housing when fully extended.
homebrew
paul
Washington
18 Wrangler JL Rubicon
Can anyone help me out with pictures of the 2.5 inch suspension lift on a Rubicon on 35s. I want to switch to a suspension lift vs the spacers and I’m on the fence between the 2.5 and 3.5
Bubba33
Saint Louis, MO
18 jeep wrangler Sahara JL
It's still a suspension lift. It's going to look 1 inch higher.
MTN1
Kingston NY
2019 Jeep jl Sport S
Happy to hear you got it figure out. Free mods/fixes are always the best :like:
Doesn't hurt to have the dual stabilizer for the "bling" and slightly stiffer steering feel. I will eventually end up with a Fox ATS or equivalent so that I can turn the stiffness all the way up on long highway trips, and all the way down when I go crawling.
Love both Jeeps. just purchased 2019 jl sport 4dr. Had 1975 cj5 in HS. Looking update tires, like the jl, that has the RC 2.5 spacer and 315x70x17 ko2's is that correct?
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Thanks. I'm not sure which picture you are referring to?
The 315/70r17 KO2's in a C Load rating are a nice riding tire. My wife and I both have mud terrains, but I've installed plenty of kits with those KO2's and they ride great.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Here is my Sahara JLU after @TTEChris worked his magic on my lift, tires, winch etc.... Tankcustoms here is Houston is the only place to go to have your Jeep modded as Chris takes his time and never takes shortcuts
RC Budget boost with BFG 315’s wrapped around Method wheels and then in the last pic a Roam bumper with RC winch and off-road CREE lightbar
MTN1
Kingston NY
Looks great! The look I want to have. Going with the 2.5 RC and 315x70 KO2's, where did you get the Roam bumper?
WranglerMan
Will
Katy Texas
Gas Pipeliner
@MTN1 I purchased the complete bumper, winch and light setup from Tankcustoms here in Houston, I believe ROAM off-road is located in Spring Tx
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
