mullerjd
- J
- Feb 5, 2019
- Saratoga, NY
- 18 JLU Sport S, 14 Ram Promaster, and some bikes
Sorry, my Rubi no longer sits at that height (different suspension and bigger tires) otherwise I would be happy to measure it for you.From the ground to the soft top, exactly how tall is your Rubi?
Clean!!Got new wheels after a year of riding with stock tires and rims with RC 2.5in kit. I love the new look.
You don't have to, but removing the 4 bolts does make it a little easier without putting too much stress on the joint housing on the transfer case side. I've swapped springs without disconnecting it a few times, but made sure the driveshaft was not resting on the housing when fully extended.For those that installed the spacer lift kit themselves, was it necessary to disconnect the driveshaft from the front axle like they describe at the very beginning of the instructions? Other spacer lift kits don't have this step, so I'm curious if (and why) anyone else did this step.
Couldn't be happier with mine so far. Had it installed about three weeks ago and have driven it a few hundred miles.
Love both Jeeps. just purchased 2019 jl sport 4dr. Had 1975 cj5 in HS. Looking update tires, like the jl, that has the RC 2.5 spacer and 315x70x17 ko2's is that correct?Happy to hear you got it figure out. Free mods/fixes are always the best
Doesn't hurt to have the dual stabilizer for the "bling" and slightly stiffer steering feel. I will eventually end up with a Fox ATS or equivalent so that I can turn the stiffness all the way up on long highway trips, and all the way down when I go crawling.
Thanks. I'm not sure which picture you are referring to?Love both Jeeps. just purchased 2019 jl sport 4dr. Had 1975 cj5 in HS. Looking update tires, like the jl, that has the RC 2.5 spacer and 315x70x17 ko2's is that correct?
Here is my Sahara JLU after @TTEChris worked his magic on my lift, tires, winch etc.... Tankcustoms here is Houston is the only place to go to have your Jeep modded as Chris takes his time and never takes shortcuts
RC Budget boost with BFG 315’s wrapped around Method wheels and then in the last pic a Roam bumper with RC winch and off-road CREE lightbar
Looks great! The look I want to have. Going with the 2.5 RC and 315x70 KO2's, where did you get the Roam bumper?
