Rough Country 2.5 inch spacer lift on JLUR, Any Regrets?
BroJrod
Jarrod
Bogalusa Louisiana
2018 JLU Rubicon
I think I'll just stick to lighter wheeling for now and wait until I wear out the 33s.
The 35s look good to me, the 37s look Beefy. Did you re-gear for the 37s or are you still running 4.10s?
When you ran 35’s on the factory wheels did you have to use spacers? I recently got a JL Rubicon and looking at this lift but want to keep factory wheels so my wife doesn’t notice!!
mschlott
mschlott
Plano, Texas
2018 Jeep Grand Cherokee Overland, 2019 JLUR
I decided to go ahead and get 35's with no lift. I have the stock wheels with no spacers and no lift. There is no rubbing even with sway bar disconnected at full flex.
boontis
Kevin
Calgary, AB Canada
2020 Wrangler Sahara Unlimited 2.0L
I've got a 2020 Unlimited Sahara and was considering this lift. Seeing the comment about the need for an adjustable track bar I had 2 questions:
1 - what causes things to get pushed to the driver side and does this happen to everyone or just in come cases?
2 - any recommendations on the best adjustable track bar?
Thanks!
Kevin
aro
2020 JLUR
1 - the fact that the track bar is not adjustable. Actually, nothing gets pushed to the driver side. The axles can't be pushed. It's in fact the body of the Jeep that doesn't sit centered anymore on the frame/axles and it moves to the right. It happens to any lifted Jeep.
2 - no one single "best" track bar. I've no experience with them, so just read around.
quietpeen
Chambersburg, PA
2019 JLUR
This is semantics.......the body sits to the right or the axle gets pushed to the left. The track bar swings on an arc so the more lift the more the offset whether it is considered the body or the axle.
CallMeJoe
William
Boyceville
I have had the RC spacer lift with shock extensions on for a year now. Works and looks great. I did also add Rubicon Express front LCA,s. My dealer did it all parts and labor for $350 with alignment. I am still running the stock K02,s on stock rims. I'm not a big fan of the Big Daddy Roth/Hot Wheels giant tire look. When I need new tires I will step up to 285/75/17 Cooper AT,s on the stock rims. I like the look. Cops like the tires in the fenderwells. It's a win/win...
dajaga
Canada
2019 Wrangler JLU Sport
I got the RC 2.5 spacer lift, I have taken the jeep out on the trails and seem to held up pretty good, I got it for the same reasons as you, a new steel bumper + winch and the front end sagged, now in saying that I quickly discouvered I need an adjustable track bar and some adjustable LCA which upped the cost quickly and probably should've held off a bit paid just a little more got a proper lift, with the shocks, springs, lca for a few hundred more. However now I got some beefy lca and track bar when the time comes for a proper lift I don't have to worry about those. I am overall happy with the RC lift and still performs on the the trails.
Stuckinthesand
CJ
NJ
2019 Wrangler sport s 2017 GMC Acadia
I’ve had this lift on my 19 Sport S for about 6 months. Have a steel front bumper and winch. I’ve run blue trails at AOAA and Raush creek on stock tires with no issues. Just went to 35’s and I still have no alignment or pulling issues with toyo open country at2 tires and black rhino Barstow 17x9.5 -18 offset.
mschlott
mschlott
Plano, Texas
I pulled the trigger on this last month and got it installed. I am very pleased at what I got for $200. It rides a little more stiff and highway fuel economy dropped again.. There is a tendency for the font end to shake when I hit bumps. It's not death wobble, but definitely noticeable. I'll probably be replacing the front lower control arms to make it a little more highway friendly.
Walter_Mustang
Adam
Oklahoma
2021 Jeep JL Willys Sport 4 door
do you have pics to show...I am also curious and possibly doing this lift...very inexpensive for $199. Thanks again!
mschlott
mschlott
Plano, Texas
AU_JLU
Australia
JLU Sport S
Can any one confirm if this is a 2.5inch lift all round? Or is it higher in the front to level the Jeep out? Thanks
TopLift Pros
