Roof rack for kayaks?
Maplecs
Oklahoma
2018 Jeep Wrangler Sahara unlimited JL
I'm looking for a roof rack so I can get a couple kayaks. Any recommendations. Would like to be able to remove freedom panels still and easily removed to take top off.
EZMFE
UT
Depends on how much you want to spend, how many you want to carry, and if you want to use the rack for other items.
Many previous threads on the subject can be found here
Click here for one to get you started.
aml
Virginia
Blue JLUR
The rhino rack backbone system is a good option, but it is expensive. I am assuming you have a hardtop? Jeep’s roof rack accessory is not recommend by Jeep to transport kayaks. External racks like Gobi’s are also good solutions.
TCogs1
Thomas
Somis
cj6
I decided to build my own (8020.net), other options are too expensive, too heavy, too big for my needs and I want to run both my soft top and hard top (or no top) while I am carrying 2 11' x 30" kayaks.
aml
Virginia
Blue JLUR
Looks nice. I like 80/20 for projects. Great stuff. How did you end up attaching it? Any pictures of it attached?
TCogs1
Thomas
Somis
cj6
Great question, this picture is hard to see but I think you will get the point. I bought some ( 4, 6x10) 3/16 304 Stainless plate on ebay ($15) cut a profile with a drill and cut off saw and bent it in a l shape (torch, hammer and vise), so the back looks like a boomerang with one end bent 90 degrees using existing hard top bolt locations and the front is similar ( z bend) except bolting to the existing holes used for the hard top panels. There is a hole for a guide pin and to the left (drivers side) there is an unused hole going through the sport cage structure.
Connecting the back brackets is .750 X 3" https://8020.net/3034-lite.html going up and connecting to a 8020 dual hinge plate ( to flip it over as a shade spot if need be). https://8020.net/4356.html.. switch connects to the quarter round https://8020.net/1517-ls.html ( I did this profile thinking it would cut the wind noise down, some, jury is out on that).
Probably not the best, but structurally stronger, lighter, narrower and cheaper (buy far) then anything I have seen on the market. And I did not have to drill any new holes in my jeep or run bars down the bumper or cowling. And I will probably keep it on my M416 trailer mostly (still have to figure out that bracketing), Jeepers Jamboree does not allow trailers.
I will send completed pictures next week when I am done. I have to be done by July 30th because that is when we leave for my bucket list Jeep Jamboree.. Which will be the ultimate test for the rack, which I think will be fine as long as I remember blue locktite :).
The down side was the time it took me to design it (Bill of material) and form - polish the brackets ~16 hours.
I hope that helps.
TC
  • Like
Reactions: aml
N.C. Jeeper
Charlotte NC
2018 Jeep JL Wrangler Sahara Unlimited
Real Estate- I can help you buy or sell anywhere!
It's a high dollar option but top of the line for sure...
I used the Rhino Rack Backbone with two Thule Hullavators (one on each side) on my JKU and have the same setup ordered for my JLUS. It'll be here 7/25/19. I carried my two 85lb fishing boats on top at 70mph with no worries what so ever. I was so happy two weeks ago when Rhino Rack finally released their JL option. The Freedom panels are still removable and the hard top is as well. The only difference is that there are two extra screws to remove from the roll bar (above the two rear doors) for removal of the hard top. It's well worth the price tag and the two extra screws.
Here's the only pic I have of my JKU outfitted.
The boat is a Native Watercraft Slayer Propel 12, a 12' kayak.
WaldorfJL
Chip
Waldorf, MD
2018 Wrangler JL
If you are in the Maryland area, local fabricator that has some really good looking work....currently ordered the kayak rack for my hobie outback to hitchmount to my 2018 JLU soft top...I will post pics when I get it....It will have the open receiver so I can also add the basket carrier (separate addition)....
CNY-JLUS
Central New York
2018 Jeep Wrangler JLU Sport S
I use Yakima 1A raingutter towers with 58" crossbars and Bow Down folding kayak racks. I carried three kayaks on a 500 mile trip on the interstate at 75 mph. Roof creaked a bit, but no problem. I mount the front rack 6" from the front edge of the raingutter on the main roof (not freedom panels) and the rear rack 36" from the front one. That spacing allows me to also use a roof storage box.
CNY-JLUS
Central New York
Has anyone found a good front tie down point for JLU Sport with plastic bumper? I thread a strap down with a hook down in front of the headlights to a hole in the frame. I'd rather have something more accessible. I am considering tying a rope around the frame in this area, leaving a loop to hook to from above. Another thought is removing the plastic rivet behind the tow hook and inserting some form of anchor with an eye bolt or eye nut to clip a carabiner to. Any suggestions on an anchor to install in this hole?
N.C. Jeeper
Charlotte NC
@CNY-JLUS
These are inexpensive and do a great job for me. Just unscrew one of the factory bolts on each side of the fender under the hood. They stay hidden under the hood until needed and then flip them out while transporting your boat or other cargo.
https://www.rei.com/product/818318/seattle-sports-hood-loops
And these for the tailgate or glass hatch. Just close them in the tailgate.
https://www.rei.com/product/818227/seattle-sports-quick-loops-pair
Pardon the JKU pic, haven’t gotten the BackBone installed on my JLUS yet.
TCogs1
Thomas
Somis
cj6
I hope that helps.
TC
Well another productive day.. rack is assembled, pivots on ( so I open and shut the soft top), rabbit ears on (front supports, allows for window and soft top operation).. tomorrow install rack to Jeep, bolt on pool floaties for kayak cushion and held to the beach for a trial run..
So far so good...
Dethwalkin
Darryn
Toronto ON
2018 JL Rubicon
Thule Hullavator. I love these. They lift 40lbs of your kayaks weight so i can literally push them up with a finger.
