Digiwolf
Next shipment is suppose to be 15 September. Hopefully if you do order, you won't be left hanging and unnotified that your reserved unit was sold to someone else.
That's for the tip. I did it... it worked... and I ordered my Rollnjack! Thanks!see my post (#57).
copied here for convenience.
“I did order it last night. So we will see how long it takes to get here.
like thunder and stealth said, I wouldn’t expect it until August. Kinda sucks, but it is what it is.
By the way, if you do order it, go through the process of ordering all the way up to just before adding payment info.
then leave it in cart and close out.
you’ll get an email about not finishing your order and will get a promo code for 10% off. That’s another $75 off.”
Yeah, I've been reading your posts. Looks like they screwed up and you've been waiting a while... sucks. At least you got a $100 discount. I was debating whether to get this or the Garage Smart system. I think I prefer the Rollnjack for kind of a weird reason... tight space, but because my garage is a lil quirky it'll be easy to have a jack on wheels and be able to roll it around in the garage than backing it up to a specific spot and lifting it. Anyway, good luck with your order... here's hoping mine comes in that same Sept shipment as well.Next shipment is suppose to be 15 September. Hopefully if you do order, you won't be left hanging and unnotified that your reserved unit was sold to someone else.
Thanks for the pic's... just ordered mine last week. Question, given where the lift pads are located when holding the top, do they rest on the cross beams on the top, or in the recessed area's? Reason I'm asking is that I've headliners in my Jeep... and I'm a little concerned that the Rollnjack may compress them over time. P.S.... Digg'in the Red color!Just finished assembling mine. I really like. The hard top won’t stay off long as the heat index is 110 here, but I had to try it out. I think I’ll always have nervousness seeing my painted hardtop suspended on anything, however, I’m sure it will be fine lol. I loved being able to take the top off myself.
Geaux Tigers!Just finished assembling mine. I really like. The hard top won’t stay off long as the heat index is 110 here, but I had to try it out. I think I’ll always have nervousness seeing my painted hardtop suspended on anything, however, I’m sure it will be fine lol. I loved being able to take the top off myself.
I've tried mine in a few different positions. The one that seems to work the best (2019 JLU with factory headliners) is when the front 2 pads are on the cross beam (basically as far forward as you can go with the jack before hitting the rollbar) and the rear 2 pads are on the headliners. All pads at the same notch height. When it lifts, most of the weight seems to be on the 2 pads with the cross beam. The rear 2 pads and the front 5th arm do touch the headliners, but they don't leave any marks on them afterwards. 5th arm is one notch higher than the other 4.Thanks for the pic's... just ordered mine last week. Question, given where the lift pads are located when holding the top, do they rest on the cross beams on the top, or in the recessed area's? Reason I'm asking is that I've headliners in my Jeep... and I'm a little concerned that the Rollnjack may compress them over time. P.S.... Digg'in the Red color!
I ran into the same issues. I actually have the 2 rear pads adjusted one notch higher than the front 2 so the pads make contact more evenly. My safety arm does not make contact.I've tried mine in a few different positions. The one that seems to work the best (2019 JLU with factory headliners) is when the front 2 pads are on the cross beam (basically as far forward as you can go with the jack before hitting the rollbar) and the rear 2 pads are on the headliners. All pads at the same notch height. When it lifts, most of the weight seems to be on the 2 pads with the cross beam. The rear 2 pads and the front 5th arm do touch the headliners, but they don't leave any marks on them afterwards. 5th arm is one notch higher than the other 4.
When I tried it with all 4 main arms on the headliners (front 2 right behind the cross beam), it didn't lift evenly. The front sagged a lot and I had to lift the entire top about a foot higher than I should have to get the front to clear the rollbar. Even though I have seen pictures of people doing it this way. Might work better on a 2door in this position.
I'll give that a try, thank you. Which level do you have the support arm set to?I ran into the same issues. I actually have the 2 rear pads adjusted one notch higher than the front 2 so the pads make contact more evenly. My safety arm does not make contact.
hey I’m so sorry. I just now saw your question. here are a couple of more pictures. I’m not sure why mine is sloping so far forward. Seems super wobbly when rolling on concrete.I'll give that a try, thank you. Which level do you have the support arm set to?
Still haven’t used mine yet, but aren’t you supposed to use the 5th arm/pad to support and stabilize it in the front?hey I’m so sorry. I just now saw your question. here are a couple of more pictures. I’m not sure why mine is sloping so far forward. Seems super wobbly when rolling on concrete.
yes and I do, I had just taken it off to put the top back on. I talked to rollnjack the first time I used it and they said the arm isn’t supposed to touch, it’s just there as a safety. I don’t know, theproduct videos just look way more stable than mine do lolStill haven’t used mine yet, but aren’t you supposed to use the 5th arm/pad to support and stabilize it in the front?
I roll the jack into the Jeep and start to crank it up to get the entire pad over the roll bar. That lets me get it a little further forward than yours is in the pictures. I basically have the pole under the pad pressing against the rollbar as I raise the top up. That helps a little more of the weight stay towards the rear and the front doesn't sag as much. My 5th arm is one notch higher than my other 4 arms. It does touch the top, but barely.yes and I do, I had just taken it off to put the top back on. I talked to rollnjack the first time I used it and they said the arm isn’t supposed to touch, it’s just there as a safety. I don’t know, theproduct videos just look way more stable than mine do lol
